Battery nut
logepoge1
Battery nut
Post by logepoge1 »
Lost the but that goes in the battery terminal. Where can I find a replacement and what is cheap remedy until then?
katschamne
Re: Battery nut
Post by katschamne »
any hardware store will have them.
logepoge1
Re: Battery nut
Post by logepoge1 »
Okay thanks. For now I wedged the battery clamp on and it seems to be working
logepoge1
Re: Battery nut
Post by logepoge1 »
I really hate those things. There has to be a better way to secure them on there. Might glue some plastic to keep it from coming out
scisor34
Re: Battery nut
Post by scisor34 »
A dab of blue Loctite works wonders in these situations.
logepoge1
Re: Battery nut
Post by logepoge1 »
Doesn't it have to move?
scisor34
Re: Battery nut
Post by scisor34 »
I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
Re: Battery nut
Hey loge! Which nut?? (you nut!) :lol: :lol:
logepoge1
Re: Battery nut
Post by logepoge1 »
scisor34 wrote:I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
It's the but inside of the battery terminal that the bolt threads into
Alibally
Re: Battery nut
Post by Alibally »
Any nut that's the right tread and length will do. As long as it's tightened correctly there should be no need for thread locker. It's only to keep the wire on the terminal. It's better to be a clean thread as this gives a better connection.
