Battery nut
- logepoge1
Battery nut
Lost the but that goes in the battery terminal. Where can I find a replacement and what is cheap remedy until then?
- katschamne
Re: Battery nut
any hardware store will have them.
- logepoge1
Re: Battery nut
I really hate those things. There has to be a better way to secure them on there. Might glue some plastic to keep it from coming out
Re: Battery nut
A dab of blue Loctite works wonders in these situations.
Re: Battery nut
I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
Re: Battery nut
Hey loge! Which nut?? (you nut!)
- image.jpg (48.17 KiB) Viewed 2081 times
- logepoge1
Re: Battery nut
It's the but inside of the battery terminal that the bolt threads intoscisor34 wrote:I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
- Alibally
Re: Battery nut
Any nut that's the right tread and length will do. As long as it's tightened correctly there should be no need for thread locker. It's only to keep the wire on the terminal. It's better to be a clean thread as this gives a better connection.
