Unused connector
- Rickjds
- Year: 2020
- Color: Candy Luster Re
Unused connector
I noticed this unused connector right next to the negative battery cable but was not hooked up to the battery. Anyone know what this is for?
- IMG_3065.JPG (71.91 KiB) Viewed 5864 times
- IMG_3064.JPG (90.87 KiB) Viewed 5864 times
- Bash On!
Re: Unused connector
Looks like it might be a data link connector for using OBD.
Check out the wiring diagram here, and see if it matches the wire colors:
http://www.hondapcx.org/viewtopic.php?f=15&t=771
2013 Silver Wing ABS (Black)
1971 BMW R75/5 (White)
- honkerman
That is the diagnostic plug. You can plug a computer into it, or there is a special jumper you can get that will trigger the display on the dash to show any active error codes.
LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
- honkerman
I've used that very plug with full diagnostic software on my own PCX. It was a third party diagnostic suite, but Honda has their own as well. As for the Jumper, the manual lists it as SCS device connector. See pic.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
The jumper causes a light on the dash to blink in a pattern, which corresponds to a code. It's a little obtuse, but it works.
- image.jpeg (53.13 KiB) Viewed 5816 times
- Oyabun
- Year: `12,`15,`19
- Color: black&black
It is not a true standard OBDII implementatation, as ghatvus not required for bikes. However it is a full diagnostic port which can be used with a scantool.chicaboo wrote:If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
- honkerman
Oyabun wrote:It is not a true standard OBDII implementatation, as ghatvus not required for bikes. However it is a full diagnostic port which can be used with a scantool.chicaboo wrote:If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
You just need the right tool.
Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
I thought the ECU gave the codes on the dash whether the device is plugged in or not? Some people report problems with their bikes and the dash light flashing short / long flashes. So, this port is needed for general 'mil code alerting'?
- Oyabun
- Year: `12,`15,`19
The dash light signals general fault, but the mil code is blinked by the diagnostics sequence initiated by the plug. It also enables clearing the codes.iceman wrote:I thought the ECU gave the codes on the dash whether the device is plugged in or not? Some people report problems with their bikes and the dash light flashing short / long flashes. So, this port is needed for general 'mil code alerting'?
A Scantool has more diagnostic possibilities though - so one can monitor all kinds of parameters measured and provided by the ecu, not just the fault codes.
- honkerman
Yep, that's the one. Punch in that part number and you can get one off partzilla.homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
As far as the software goes and computer cable goes, they had it at the school I attended. I don't remember who made it, but I can probably find out.
A paperclip from the stationary cupboard?homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
Excellent Honky! I will take that, yes please go find us the program and we shall see what kind of sensors are install on the Precioushonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla.homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
Wait I don't have a 2016/17 PCX and there is no unused connector or a half dosen cool sensors monitoring the Precious
boooooooooooooooo never mind
- honkerman
I can tell you right now, it doesn't have a tip-over sensor.
Not sure if that's just a wire, resistor or diode wrapped up in a candy shellhonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla. http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
- honkerman
Just a wire. Lol.iceman wrote:Not sure if that's just a wire, resistor or diode wrapped up in a candy shellhonkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla. http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
