Unused connector
Rickjds
Year: 2020
Color: Candy Luster Re
Unused connector
Post by Rickjds »
I noticed this unused connector right next to the negative battery cable but was not hooked up to the battery. Anyone know what this is for?
Bash On!
Re: Unused connector
Post by Bash On! »
Looks like it might be a data link connector for using OBD.
Check out the wiring diagram here, and see if it matches the wire colors:
http://www.hondapcx.org/viewtopic.php?f=15&t=771
2013 Silver Wing ABS (Black)
1971 BMW R75/5 (White)
honkerman
Post by honkerman »
That is the diagnostic plug. You can plug a computer into it, or there is a special jumper you can get that will trigger the display on the dash to show any active error codes.
LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
chicaboo
Post by chicaboo »
homie wrote:LOL.. I don't think so, but I wish they would allow for user interface with full diagnostic software.
If it was a standard OBDII port like in cars, you could connect an ELM327 or similar dongle and bluetooth that information to your smartphone for full realtime display of all information.
honkerman
Post by honkerman »
I've used that very plug with full diagnostic software on my own PCX. It was a third party diagnostic suite, but Honda has their own as well. As for the Jumper, the manual lists it as SCS device connector. See pic.
The jumper causes a light on the dash to blink in a pattern, which corresponds to a code. It's a little obtuse, but it works.
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
It is not a true standard OBDII implementatation, as ghatvus not required for bikes. However it is a full diagnostic port which can be used with a scantool.
honkerman
Post by honkerman »
You just need the right tool.
Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
I thought the ECU gave the codes on the dash whether the device is plugged in or not? Some people report problems with their bikes and the dash light flashing short / long flashes. So, this port is needed for general 'mil code alerting'?
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
iceman wrote:I thought the ECU gave the codes on the dash whether the device is plugged in or not? Some people report problems with their bikes and the dash light flashing short / long flashes. So, this port is needed for general 'mil code alerting'?
The dash light signals general fault, but the mil code is blinked by the diagnostics sequence initiated by the plug. It also enables clearing the codes.
A Scantool has more diagnostic possibilities though - so one can monitor all kinds of parameters measured and provided by the ecu, not just the fault codes.
honkerman
Post by honkerman »
homie wrote:Ah yes.... the little jumper that gives you a morse code like sequence for general diagnosis on the road. These are small, handy and very portable. I keep one on board, so where do you get one for the Honda?
Yep, that's the one. Punch in that part number and you can get one off partzilla.
http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
As far as the software goes and computer cable goes, they had it at the school I attended. I don't remember who made it, but I can probably find out.
chicaboo
Post by chicaboo »
A paperclip from the stationary cupboard?
Excellent Honky! I will take that, yes please go find us the program and we shall see what kind of sensors are install on the Precious 8) I know you can make your own jumper but you need the codes. WOOT... I love stats, details and decoder spy stuff :lol:
Wait I don't have a 2016/17 PCX and there is no unused connector or a half dosen cool sensors monitoring the Precious :x
boooooooooooooooo never mind :oops:
honkerman
Post by honkerman »
I can tell you right now, it doesn't have a tip-over sensor.
honkerman wrote:Yep, that's the one. Punch in that part number and you can get one off partzilla. http://www.partzilla.com/parts/detail/h ... oCOC3w_wcB
Not sure if that's just a wire, resistor or diode wrapped up in a candy shell :)
honkerman
Post by honkerman »
Just a wire. Lol.
