Mirror extensions
wojtek_pl
Year: 2014 PCX 125
Color: matt black
Re: Mirror extensions
Post by wojtek_pl »
Hi,
Anyone knows if those extenders will fit to PCX ? So far I discovered I have reverse thread too.
Regards
Wojtek
2014 Honda PCX 125
NeilForza wrote:
dergav wrote:Neil...And remember...as Fish advised above...you will need a split washer as the screw in bottoms out before fully screwed in...if you see what I mean!
Mine came in the post yesterday so a job for the weekend :)
I noticed a split washer in the pack already, are you saying use one with each section? ie. where you bolt onto the bike and again where the mirror stem connects to the extender?
Also after a very quick look at the packs last night I noticed the hex/allen bolt head is quite large, any idea of the size you used as I'm positive I don't have one that large
It's an 8mm allen wrench....and I have the washer directly under the black extension base to 'lift' the allen bolt a touch so it does not bottom out in the threaded part of your scooter. Otherwise the allen bolt 'bottomed' in the scooter hole and the whole enchilada would not tighten.
Without the washer I found that I had mounted two reverse thread propellers on my scoot.
pcxpower
Post by pcxpower »
wojtek_pl wrote:Hi,
It's strange... my PCX is also a 2014 model, like yours (2015 model in the States) and both sides have regular thread... my PCX was built in Italy: perhaps yours was built in another country?
2015 Honda PCX 125
pcxpower wrote:
wojtek_pl wrote:Hi,
This is because you are above the equator.
Honda Co. are very smart people to think of this! :-)
pcxpower
Post by pcxpower »
:D :D :D :D :D :D :D
2015 Honda PCX 125
NeilForza
Year: 2014 Forza
Color: Silver
Post by NeilForza »
I fitted mine over the weekend and this morning’s ride into work was the 1st time used.
What a great difference they made, now I can glance at my mirrors and see what’s coming. No more looking at the mirror and shifting to the side a bit to see!
I would recommend these for sure, these or longer mirrors :roll:
NeilForza wrote:I fitted mine over the weekend and this morning’s ride into work was the 1st time used.
Yes, the first thing I do with a new bike is fit some mirrors that work! At my age, (&at the speed I ride)most of the exciting stuff is happening behind me. All the mirrors look cool on the showroom floor ....very few of them work as intended. Glad you're safer now! Regards, Fish
riderthailand
Color: Grey
Post by riderthailand »
Any idea if convex mirrors for Forza available
Dufus
Post by Dufus »
fish wrote:These worked well for me on my new Forza.
The allen screw/bolt is slightly too long...bottoms out in the brake lever housing hole. I just added one thick split washer and it snugged right up with no further issues.
Wasn't certain if these would work....the lefty threads on both sides of the Forza confused me.
Now I can see better behind me.
http://www.ebay.com/itm/400731358154?_t ... EBIDX%3AIT
Thanks Fish! $10 vs. $116? What's not to like?!
My final, and best solution to the Forza mirror problem...was fitting a pair of Honda 500X mirrors.....exact same Forza mirrors but with perfectly longer stems!
Keeping the Honda OEM look....much better than the extenders goofy appearance.
My final, and best solution to the Forza mirror problem...was fitting a pair of Honda 500F mirrors.....exact same Forza mirrors but with perfectly longer stems!
Dufus
Post by Dufus »
[quot="Dufus"]eThanks Fish! $10 vs. $116? What's not to like?![/quote]
Fish[/quote]
And how do they interface with the tall one-piece Givi windscreen? Any parts collisions at full steering lock? And since it's now appeared as both 500F and 500X, which is it, or are they the same?
chicaboo
Post by chicaboo »
Dufus wrote:and since it's now appeared as both 500F and 500X, which is it, or are they the same?
I googled the images for both bikes, and I can't tell the mirrors apart. So maybe they are the same?
Sorry for confusion...my son has the X ....not the F -- he reminded me.
Visit a Honda motorcycle dealer...you'll see longer stem Forza mirrors on the 500X.
Short answer for Forza owners: great OEM looking mirrors with safer rear view for larger riders.
Dufus wrote:[quot="Dufus"]eThanks Fish! $10 vs. $116? What's not to like?!
Fish[/quote]
And how do they interface with the tall one-piece Givi windscreen? Any parts collisions at full steering lock? And since it's now appeared as both 500F and 500X, which is it, or are they the same?[/quote]
Would not think a longer mirror stem will cause any interference with any screen unless your present mirror body is inside the cofines of the screen itself. . Longer stems move mirror out maybe 1.5" - 2.0"....stem is in same place as orig Foza mirrors.
Yes, the mirrors on the CB500F and CB500X are exactly the same.
Right: http://www.bike-parts-honda.com/microfi ... Z-J40.html
Left: http://www.bike-parts-honda.com/microfi ... Z-J40.html
http://www.bike-parts-honda.com/pieces- ... F+ABS.html
MBMyer
Post by MBMyer »
Here's a picture of a stock Forza mirror sitting next to a CB500X mirror:
older post with picture
I like the longer stem; it allows me to see what's behind me more quickly.
MMe
6 other previous bikes
Road-Dog
Post by Road-Dog »
here was my solution that works extremely well and was dirt cheap
Road-Dog wrote:here was my solution that works extremely well and was dirt cheap
What was is it?
MBMyer
Post by MBMyer »
What was is it?
He cut the mirror arms, cut a piece of aluminum tubing, slid both parts of the mirrors into the tubes, added epoxy and some paint. Note the ridge near the bend above where the mirror screws into its mounting hole.
Cf. his post in the "Submarine Work" thread:
http://hondapcx.org/viewtopic.php?f=21&t=6606
