Stuck Screw On Front Brake Master Cylinder
JPCX
Post by JPCX »
Hello all
Today I tried to change my own brake fluid on my 2016 PCX150 for the first time and I cannot for the life of me remove one of the screws on the reservoir cap.
I used the correct size screwdriver, WD-40, rubber bands and a hammer on the screwdriver with zero luck. Has anyone had experience with a stubborn or stripped screw? What can I do here to remove it without damaging anything else?
Also, does anyone have a reliable site to order a new screw from? I found hondapartshouse.com, but I'm not sure if there's better sites out there. Thanks!
power-full
Year: 2010
Color: preta
Re: Stuck Screw On Front Brake Master Cylinder
Post by power-full »
good morning I usually use wurth boltex
Also keep in mind that this bike uses JS head screws, not PhillIps Head. That makes a difference when the screw is stubborn.
springer1
Year: 2018
Post by springer1 »
Code: Select all
Nice Tip (no pun intended)
JPCX
Post by JPCX »
Thanks all. I've ordered a JIS screwdriver with a few different tips for it and will leave it alone until it arrives. I don't want to strip it more than I already have. Will update when I try it.
JPCX
Post by JPCX »
Just got my JIS driver and it removed the screw no problem, even in this partially stripped state. Ordered a couple of extra screws to replace the current ones just in case.
springer1
Year: 2018
Post by springer1 »
Thanks for the feedback!
pxc-in-japan
Post by pxc-in-japan »
I change my brake fluid a little more often than most. Once a year and again after replacing the brake pads. (I know some will say that is too often, but it does not harm and takes very little fluid.) I suggest that, even if you do not change the oil so often, you could give the screws half a turn out and back in again a couple of times a year. That should keep them from getting stuck, and will take no more than 20 seconds.
http://www.fuelly.com/motorcycle/honda/pcx150/2015/staninjapan/408151]Image
pxc-in-japan
power-full wrote: Sun Jul 25, 2021 2:59 am good morning I usually use wurth boltex
Is this equivalent to WD40?
On my previous bike I killed one of the screws trying to get it out of the master reservoir.
Wonder if i can get the one you use here in Japan,
Mon-Eye
Year: 2021
Post by Mon-Eye »
Impact driver will crack that off straight away. Best place for parts on UK is David silver spares or wemoto
CBR1100XX blackbird (modified), CBR929RR Turbo, CBR600F Sport (modified), several beta trials bikes and endurance bikes
Monty
Year: 2012
Post by Monty »
Mel46 wrote: Sun Jul 25, 2021 9:42 amkeep in mind that this bike uses JS head screws, not PhillIps Head
Great tip, as missing from my tool box ... now on order. Thanks!
