Stuck Screw On Front Brake Master Cylinder
JPCX
Hello all
Today I tried to change my own brake fluid on my 2016 PCX150 for the first time and I cannot for the life of me remove one of the screws on the reservoir cap.
I used the correct size screwdriver, WD-40, rubber bands and a hammer on the screwdriver with zero luck. Has anyone had experience with a stubborn or stripped screw? What can I do here to remove it without damaging anything else?
Also, does anyone have a reliable site to order a new screw from? I found hondapartshouse.com, but I'm not sure if there's better sites out there. Thanks!
- image0.jpg (64.48 KiB) Viewed 8483 times
- power-full
- Year: 2010
- Color: preta
Re: Stuck Screw On Front Brake Master Cylinder
good morning I usually use wurth boltex
- IMG_20210725_085811.jpg (35.54 KiB) Viewed 8476 times
Also keep in mind that this bike uses JS head screws, not PhillIps Head. That makes a difference when the screw is stubborn.
springer1
- Year: 2018
Code: Select all
Also keep in mind that this bike uses JS head screws, not PhillIps Head. That makes a difference when the screw is stubborn.-
JPCX
Thanks all. I've ordered a JIS screwdriver with a few different tips for it and will leave it alone until it arrives. I don't want to strip it more than I already have. Will update when I try it.
JPCX
Just got my JIS driver and it removed the screw no problem, even in this partially stripped state. Ordered a couple of extra screws to replace the current ones just in case.
springer1
- Year: 2018
Thanks for the feedback!
pxc-in-japan
I change my brake fluid a little more often than most. Once a year and again after replacing the brake pads. (I know some will say that is too often, but it does not harm and takes very little fluid.) I suggest that, even if you do not change the oil so often, you could give the screws half a turn out and back in again a couple of times a year. That should keep them from getting stuck, and will take no more than 20 seconds.
http://www.fuelly.com/motorcycle/honda/pcx150/2015/staninjapan/408151]
pxc-in-japan
Is this equivalent to WD40?
On my previous bike I killed one of the screws trying to get it out of the master reservoir.
Wonder if i can get the one you use here in Japan,
Impact driver will crack that off straight away. Best place for parts on UK is David silver spares or wemoto
