GPS Mount for new Forza 300??
rollmops
Year: 2018
Color: Silver/Black
Post by rollmops »
Did someone find a solution to mount a smartphone/GPS on the new Forza 300?
I am thinking of using the RAM-B-346U and Drill one extra hole.
Code: Select all
https://www.ram-mount.co.uk/reservoir-cover-base-with-1-ball-offset-mounted-p-1567.html?sesid=51fku112646ugt326e0h94flv4
Oldie
Year: 18 PCX 125
Re: GPS Mount for new Forza 300??
Post by Oldie »
There's the option of mounting a Ram ball in the "false" mirror mounts, probably the r/h side is best for space. A central location would be better and I guess that's what you're planning with your modification?
rollmops
Year: 2018
Color: Silver/Black
Post by rollmops »
Oldie wrote:There's the option of mounting a Ram ball in the "false" mirror mounts, probably the r/h side is best for space. A central location would be better and I guess that's what you're planning with your modification?
Where are the "false" mirror mounts ?? the one on the photo?
Looks the are made from Plastic.
Just for ya hazzzz check out what this guy did . . ..
Where there's a will there's a way I guess. It's en francais but a close up of the gadget appears around 1:25 into the vid.
Oldie
Year: 18 PCX 125
Post by Oldie »
rollmops wrote:Where are the "false" mirror mounts ?? the one on the photo?
Those are just dummy inserts. Remove them and you have a normal threaded hole to screw in your Ram..
Spaguar
Year: 2018 Forza 125
Color: Silver/Pacific
Post by Spaguar »
rollmops wrote:Did someone find a solution to mount a smartphone/GPS for the new Forza 300?
I have used this original Givi mount https://www.forza125shop.com/en/comfort ... g-kit.html .
Since I've installed my termoscud PRO, I am using their system to mount my smartphone/GPS.
My Givi mount+ optional smartphone bag is now for sale if you are interested.
Let me know.
rollmops
Year: 2018
Color: Silver/Black
Post by rollmops »
There seems too be different threaded mounts..What is normal??
Oldie
Year: 18 PCX 125
Post by Oldie »
Stick a few different bolts in the threaded hole and see what size fits. Then order a ram mount with a similar thread.
davenowherejones
Color: Silver
Post by davenowherejones »
Might be left hand threads so insert bolts cautiously.
Really, That's cool Oldie! How does one know that, does it mention those phonies in the owners manual, or You know that from probing around? I dig Bonus' like that! 8)
Oldie
Year: 18 PCX 125
Post by Oldie »
WhiteNoise wrote:That's cool Oldie! How does one know that
Well, I could just be an engineering genius, or else I read about it on another forum :D
Cool dude!
Spaguar
Post by Spaguar »
What I did was I took the plastic insert to the hardware store, tried out which nut fits it and then chose the screw that fits that nut.
The thread is really not "normal" but, what we call a "fine thread" and it is a right thread.
The new screw has to be a bit longer then the plastic one.
Great advice! ^
davenowherejones
Color: Silver
Are both plastic inserts the same? Or one is a reverse thread?
Spaguar
Post by Spaguar »
davenowherejones wrote:Are both plastic inserts the same? Or one is a reverse thread?
I've only done it on the left one. It's easy to find out. All you need is a regular screwdriver. If it's left, it's left. If it's right, it's right. It's simple as that.
rollmops
Year: 2018
Color: Silver/Black
Post by rollmops »
Received my ram mount today and it fits.
( RAM-B-349U )
However there is very little space left.The right side has more space.
Bit of a shame really because of the 12 v plug .
Year: 26 adv 160
Any machine shop can make you a 2 inch extension and collar out of stainless rod and thread it...;For probably less than 25 bucks.
I have a PCX so this may not apply to the Forza, but I found out that RAM has some brake reservoir covers that fit my particular year, so that is where my mount is. I actually used one that worked on my Burgman 400. Maybe you can measure the cover and look for one with the same dimensions.
https://mounts.factoryoutletstore.com/C ... l%20Offset
rollmops
Year: 2018
Color: Silver/Black
Post by rollmops »
I made 2 extention from aluminium too get the RAM Mount further away from the Breakfluid container.
