obd2 port 4 pin to 16 pin wiring diagram help
kevkev45
Post by kevkev45 »
can some one help.? i need diagram for this.
i need to connect it bluetooth obd2 so that i can see the rpm and tune the variators
thank you!
Re: obd2 port 4 pin to 16 pin wiring diagram help
Welcome
Have you seen this thread? viewtopic.php?f=9&t=8991
Ok, I see you have. Wait a bit, Good luck
kevkev45
Post by kevkev45 »
WhiteNoise wrote:Welcome
yes i have seen that. but i cant buy the connector here in my place or order it online.. i just need the diagram so i can DIY it
Maybe a silly question but have you searched online for a diagram?
I typed this into my google search bar:
1) obd2 port 4 pin to 16 pin wiring diagram for bluetooth adaptor Elm327
2) Need wiring diagram for bluetooth adaptor Elm327 to obd2 port 4 pin to 16 pin
When the pages came up, I immediately clicked on the "image tab" (at the top of the page).
Boom! Lots of illustrations/diagrams appeared.
Is that what You Need? Hmm, I'm Not sure, but maybe they'll serve as a pathway .
Tweak my search wording (to your liking), you may find the answer to your question(s).
Keep us posted. I wish you luck :)
I'm now just getting this. (Guessin' I've Poor reading skills this afternoon, sorry)
You haven't any parts. You want to create and need a master plan/diagram to make it happen.
Wow, I was confused :oops: Probably still am.
Alrighty then, I'm outta here!
We'll wait for our knowledgable members to come along.
(To members, Is it Me? :geek: )
kevkev45
Post by kevkev45 »
done. i've got it already and its working !
That's Great kev! 8) How's that working for ya? What did you do? What diagram did you find/use? Your input here could be very useful to someone needing the same. And of course, adding links and photos are a big +
Congrats!
WhiteNoise wrote:That's Great kev! 8) How's that working for ya? What did you do? What diagram did you find/use? Your input here could be very useful to someone needing the same. And of course, adding links and photos are a big +
Congrats!
Got to admit I’d be interested.
kevkev45
Post by kevkev45 »
i just want to see the engines status when at full throttle and the ignition timing if I change octanes. here is the video
before at full throttle it was open only at 87% then i adjust the throttle linkage and bent something and now it is 93.7% at full throttle
https://drive.google.com/file/d/13P9qBG ... sp=sharing
grndslm
Post by grndslm »
How about the final draft of your schematic, kevkev?
We ALL want to know...
raito
Color: matte silver
Post by raito »
I just got adapter from Webike Japan made by Kitaco but still waiting for Bluetooth scanner. BTW how do I take the cover off the 4-pin port on the bike? I can't seem to find the tabs to unhook..
raito
Color: matte silver
Post by raito »
raito wrote:BTW how do I take the cover off the 4-pin port on the bike? I can't seem to find the tabs to unhook..
Nevermind this, I figured it out :oops:
Sergio
Post by Sergio »
kevkev45 wrote:can some one help.? i need diagram for this.
thank you!
Hi all, new here with some issue in mine and the same problem...Could you please share the diagram KevKev? Thanks!
brm2
Year: 2012
Post by brm2 »
hi. is this what you want?
https://ibb.co/1dJSxNk
Conelite
Color: Blue
Post by Conelite »
I have the Same Kitaco adaptor and the same bluetooth OBDII scanner which does not work at all.
BRM2, Have you attempted to repin the 16 to the 4 corners like the diagram shows?
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
brm2
Year: 2012
Post by brm2 »
I didn't try it. Should work.
jb1987
Post by jb1987 »
Hello, I have tried to make an adapter with the diagram in the attached photograph for conelit and I have not had results. Are you sure that the arrangement of the cables is correct?
thanks a lot
jb1987
Post by jb1987 »
Conelite wrote:I have the Same Kitaco adaptor and the same bluetooth OBDII scanner which does not work at all.
hello conelite,
I have checked your diagram and have had no luck. Are you sure the diagram is correct? I have also found the following diagram that looks very different from the kitaco adapter.
[img]https://kds-online.de/images/product_im ... 0x0780.jpg[/img]
The issue seems to revolve around pin 9 of the OBD connector as the other 3 are common standards - pin 9 is one of the model specific ones.
