Hi
Does someone know what work has to be done for the 12000 miles service?
My local Honda dealer is quoting me 160£, twice as much then the 8000m service.
Thanks.
rollmops wrote:Hi
Thanks.
Here is 2018 Forza 125 Maintenance Schedule
Maintenance Schedule.png (218.28 KiB) Viewed 7657 times
I'll take the liberty to hijack this thread a little if I may as 12k service include valve clearance inspection.
Does anyone with the service manual for 2018< 125 Forzas know the valve clearance values?
And if somone have the torque values for the cylinder head cover I will be all set.
£160 for an oil change , I got quoted similar for my first service, did it myself, do you trust them enough to believe they will do the valve inspection?, if there are panels to remove on the 125 put some clear sticky tape on them and see if its been removed when you get it back.
mark the nuts on the case cover to see if they removed them to check your belt as well, there not called stealerships for nothing, i trust no one, it has to be earned.
Haarek wrote:I'll take the liberty to hijack this thread a little if I may as 12k service include valve clearance inspection.
Is there not a sticker under the seat with the engine specs: valve gap, spark plug type and gap, etc., etc.?
Scoots sold in USA have this info posted there....
and this info supercedes any info in a manual!
I wouldn't trust torque specs for the cylinder head cover. Someone else on this forum tried to torque theirs to spec and broke the bolt. Just hand tighten those plus 1/4 turn with wrench. You can feel when it is tight enough.
Red 2013 Honda PCX150 Givi tall windshield & tailbox - Lots of extra lights Custom seat from Thailand - Bad Boy Airhorn Takegawa Lowering Shocks - Michelin City Grip Tires Headlight assy upgraded to LEDs w/HS5 main bulbs NCY variator, drive face, and rollers
Mel46 wrote:I wouldn't trust torque specs for the cylinder head cover. Someone else on this forum tried to torque theirs to spec and broke the bolt. Just hand tighten those plus 1/4 turn with wrench. You can feel when it is tight enough.
