It doesn't protect the engine, but its supposed to protect the CVT cover.
Any degree of impact would force that into the CVT cover and you will end up with two damaged items, and difficulty removing the bent/snapped bolts to replace either...
The only thing that is good for is protecting you from your money and looking good.
I've yet to see a CVT cover what was damaged to an extent of essentially inmobilizing a PCX. I can imagine that this protects from a standstill fall, but not a slide. As Chicaboo mentioned with this installed there's a high chance that an otherwise bad looking but not serious cover damage would end up in a more serious stuff - rendering the scoot stranded and requiring change both parts.
Besides i don't like the looks of it either - too much edges and bling for my eyes. A new OEM CVT cover is ~40EUR plus shipping from Bikerzbits - this one costs 60.
So my conclusion is. If you like the looks of it - go and buy one. But it is certainly not useful nor saving you money or effort in case of a fall.
I have the exact same CVT cover guard/protector and one on the other side to protect the muffler (see pics below).
I laid my PCX down on the CVT side at slow speed on very smooth and slippery concrete. My foot got caught between the ground and the seat. The was no damage to the CVT cover or the guard/protector. The bolts did not bend.
As far as the expense of the guards, because I am in Thailand they are very inexpensive. I can't recall exactly how much they cost, but I am positive they were less than $30 each, and likely closer to the $15-$20 range.
I put them on for two reason. 1) I like how they look, and 2) To help protect against curb scrapes which are not uncommon when riding between the curb and cars waiting for lights to change, which a common practice in Bangkok.
PCX Canister Breather 02.jpg (91.99 KiB) Viewed 4457 times
PCX Canister Breather 01.jpg (100.73 KiB) Viewed 4457 times
Kramnala58 PCX Exhaust.jpg (111.57 KiB) Viewed 4457 times
2010 Honda PCX 125 in Thailand (White) - "White Lightning"Sold in Sept 2017 2009 Yamaha Majesty YP400 in USA (Metalic Titanium) - "The Throne"Sold in June 2020
That is because it didn't make contact since the centre stand sticks out further when retracted.
If your stand was pushed down by a slide/spin you would find it to be a very different story.
Jge64 wrote:Do you have a link for that air cleaner? Very nice looking......
Sorry, I bought it off the shelf at a small local shop here. I looked online, but don't see one.
It gives the bike a bit more of a throaty sound.
I laid my bike down on it left side at 45 mph to avoid an accident in front of me. The damage to the CVT cover is so minor that I didn't even replace it. Maybe I will some day, but in reality there are some scratches at the bottom bolt area and that is it. Between the center stand and other things the cover must have hardly touched the pavement.
Red 2013 Honda PCX150 Givi tall windshield & tailbox - Lots of extra lights Custom seat from Thailand - Bad Boy Airhorn Takegawa Lowering Shocks - Michelin City Grip Tires Headlight assy upgraded to LEDs w/HS5 main bulbs NCY variator, drive face, and rollers
Mel46 wrote:I laid my bike down on it left side at 45 mph to avoid an accident in front of me. The damage to the CVT cover is so minor that I didn't even replace it. Maybe I will some day, but in reality there are some scratches at the bottom bolt area and that is it. Between the center stand and other things the cover must have hardly touched the pavement.
Using you as an example, what do you think would happen to something sticking out an extra inch beyond the CVT with long skinny bolts?
When designed correctly, all these protective guards and sliders do is save your bike to a degree from a standing or low speed drop. Which is cool.
But in Mel's case, frame/fork/axle sliders would've just sheered off leaving behind broken bolts and potentially transferring damage to the chassis that may have otherwise been fine, just so the cheap exhaust and plastics won't get scratched, which they still most likely will anyway.
Kind of a bummer having to replace your swingarm and forks now because they got torqued over by frame sliders.
Very true. I am pretty sure that protector would have caused more damage than it was meant to. I wouldn't put one on my bike, that is certain.
