Metal side panel, where to buy?
kar120c
Year: 2015 Forza 300
Post by kar120c »
hostare immagini
the circled part
kar120c
Re: Metal side panel, where to buy?
Post by kar120c »
anyone? I need it!!
davenowherejones
Post by davenowherejones »
kar120c wrote:anyone? I need it!!
Why? For cooling or to look cool?
What is it made of? A local sheet metal place might be able to make you one quickly.
dergav
Color: grey
Post by dergav »
my 2014 Forza does not have that plate....
your pic made me go out to my garage to have a look!!
Do you know what it is for?
davenowherejones
dergav wrote:?
It is for access to the spark plug I think. Normally it is plastic with no vents.
kar120c
Post by kar120c »
I need only beacuse it is looking cool!
DioTiAma
Year: 2013 NSS300A
Color: Seal Silver
Post by DioTiAma »
Paint it, carbon fibre look. You will not be able to find that part anymore.
Honda Forza NSS300A.jpg (187.71 KiB) Viewed 5831 times
kar120c
Re: ...
Post by kar120c »
DioTiAma wrote:Paint it, carbon fibre look. You will not be able to find that part anymore.
Why do you say this? is an out of stock part? who sold it?
DioTiAma
Year: 2013 NSS300A
Color: Seal Silver
Post by DioTiAma »
Since you are so insistive... That thing is not an aftermarket part! It's a modification. You cut the existing piece of plastic and you combine it with a floor drain cover! Voilà!
Floor Drain Cover.JPG (20 KiB) Viewed 5801 times
kar120c
Re: ...
Post by kar120c »
DioTiAma wrote:Since you are so insistive... That thing is not an aftermarket part! It's a modification. You cut the existing piece of plastic and you combine it with a floor drain cover! Voilà!
I am am so insistive because almost every Thai tuned Forza has this panel and it is the same for all
kar120c
Post by kar120c »
Found it!
Image image share
Life has meaning once more
Ok, that's great! Sometimes it's the small things in life that makes one happy ;) I get it. Me too, lots of times. Appreciate that others were trying to help by providing a different replacement. Cheers to You, you found it after all :) Can you share with us where? Thanks up front 8)
2yous...Rejoice :D
kar120c
Post by kar120c »
WhiteNoise wrote:Ok, that's great! Sometimes it's the small things in life that makes one happy ;) I get it. Me too, lots of times. Appreciate that others were trying to help by providing a different replacement. Cheers to You, you found it after all :) Can you share with us where? Thanks up front 8)
2yous...Rejoice :D
From a Thai user of the "Forza Club Thailand", send me pm if you want more informations
Here you can see the part mounted on my Forza
Image upload immagini gratis
MBMyer
Post by MBMyer »
Nice!
Is it functional as well, or merely decorative? And if functional, in what way?
6 other previous bikes
2yous...Rejoice :D
Hurray..
kar120c
Post by kar120c »
MBMyer wrote:Nice!
I think it is only decorative but while running more air reach the engine and this should be an advantage.
About rain, my mechanic told me is not a problem because spark has a rubber sealing
