I'll be the owner of a 2013 PCX 150 by month's end.
I see that it comes standard with halogen headlights. Is there any real advantage to changing to LED lights? If so, which color?
Halogen vs LED?
Re: Halogen vs LED?
Absolutely none.kjmillig wrote:Is there any real advantage to changing to LED lights? If so, which color?
- JohnL
- Ozzie Old Fart
- Color: Dark Red
Re: Halogen vs LED?
No offence meant to GN2.
It's a personal thing. GN2's answer may suit him, it doesn't mean you can't have another opinion.
I have a 2015 PCX and absolutely swear by the LED's, but that's just my opinion as I haven't ridden a PCX with halogen lights.
I also like chocolate ice cream, for what it's worth
Re: Halogen vs LED?
Which is fine, but irrelevant.JohnL wrote:I have a 2015 PCX and absolutely swear by the LED's
The PCX under discussion is a 2013 which has a completely different headlamp unit.
Re: Halogen vs LED?
The headlamp bulbs in the halogen headlamps are double filament and there are 2 of them. One filament for dipped and the other main beam. Can you even get double filament led's?
There are HID kits available and there's treads on the forum about the pros and cons
As gn2 said, the later pcx has led lamps but the headlamps are completely different.
What you need to remember is the factory set up the reflectors for the standard bulbs so fitting non standard ones may alter the pattern so it either dazzles other road users or gives dark spots.
I find the standard lights fine but others don't, but I use mine mostly where there are street lights.
Re: Halogen vs LED?
That is why some of us have added extra LED lights external to the lights already on the bike. One the American version of the 2013 PCX there are a lot of empty slots in the light assembly, but no harness setup to allow us to plug in more lights. In fact, you would have to disassemble the bike, take the headlight assembly off of the bike, drill out the holes where the lights should go, and fit a makeshift harness add-on in order to use all of the places where lights belong. Then you would have to make sure the fuses could handle the additional lights.
I would love to be able to do that, but it is an awful lot of work, and I have already reassembled my bike after the accident. I don't want to tear it down again just for more lights.
Re: Halogen vs LED?
Mel46 if I may ask do you have any pictures of these lights and install info. I bought my daughter the 2013 PCX and I want to install some aux. lights. All about being seen.
