How do use this hole?
How do use this hole??
- S51113-152353_mh1447400518446_副本.jpg (280.5 KiB) Viewed 2070 times
Re: How do use this hole?
No worries, I had the same question when I got my first PCX
That's the CBS Brake Fluid Reservoir viewing window. You can check your level by peering in (sometimes it's hard to see the level especially if the fluid is colorless or if the reservoir is full to the top). Grab a mini flashlight and jiggle the bike (carefully) if it's really full. Can you see the fluid?
Scroll down this page: http://www.hondapcx.org/viewtopic.php?f ... r&start=40
I see, thank you very much!WhiteNoise wrote:No worries, I had the same question when I got my first PCXThat's the CBS Brake Fluid Reservoir viewing window. You can check your level by peering in (sometimes it's hard to see the level especially if the fluid is colorless or if the reservoir is full to the top). Grab a mini flashlight and jiggle the bike (carefully) if it's really full. Can you see the fluid?
Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
Joey6262 wrote:Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
Green beam flashlight?
Great tip. Thanks!Joey6262 wrote:Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
