How do use this hole?
shaguyun
Year: 0
Color: 白色
Post by shaguyun »
How do use this hole?? ;)
Re: How do use this hole?
No worries, I had the same question when I got my first PCX ;) That's the CBS Brake Fluid Reservoir viewing window. You can check your level by peering in (sometimes it's hard to see the level especially if the fluid is colorless or if the reservoir is full to the top). Grab a mini flashlight and jiggle the bike (carefully) if it's really full. Can you see the fluid?
Scroll down this page: http://www.hondapcx.org/viewtopic.php?f ... r&start=40
shaguyun
Year: 0
Color: 白色
Post by shaguyun »
WhiteNoise wrote:No worries, I had the same question when I got my first PCX ;) That's the CBS Brake Fluid Reservoir viewing window. You can check your level by peering in (sometimes it's hard to see the level especially if the fluid is colorless or if the reservoir is full to the top). Grab a mini flashlight and jiggle the bike (carefully) if it's really full. Can you see the fluid?
I see, thank you very much! :lol:
Joey6262
Post by Joey6262 »
Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
Joey6262 wrote:Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
Green beam flashlight?
Great tip. Thanks! :)
