I am new at the PCX only one week, one thing i noticed today, when the bike is idleing at a stop light or when i start it up at home, is that when i apply the rear brake it idles smoother. i let the brake go it changes the idle, i apply the rear brake the idle smooths out. puzzled
Chet
when pcx is ideling
- Year: 26 adv 160
Re: when pcx is ideling
Hitting the brake engages the brake lights which might cause idle pitch to chg.....its a draw.....
j.d.b.
- Color: red
Yeah, I've noticed that, too. It's the load from pulling the rear brake cable applied to the motor-swing-arm assembly.
never noticed, must be a 2013 model thing.
j.d.b.
- Color: red
Interesting. If you would, subjectively evaluate the idle quality once warmed up. Then, squeeze the rear brakes moderately and see if it idles noticeably smoother? I don't know anyone with a '15 to try.homie wrote:never noticed, must be a 2013 model thing.
I'm wondering if Honda changed the durometer of the rubber in the mountings.
It was commented on long before that.homie wrote:never noticed, must be a 2013 model thing.
http://www.hondapcx.org/viewtopic.php?p=9520#p9520
- ScooteringAbout
Mine does this and it makes some sense.
The rear drum brake is attached to the same aluminium block as your engine, so applying the rear brake essentially clamps the rear shoes onto the whole rear hub, and thus the vibration throughout changes.
aka DrewJW
The piston moves backwards and forwards and shakes everything backwards and forwards.
With the front brake applied there is probably enough flex in the forks to allow the fore and aft movement to continue.
