honda pcx stop start technology
the stop start technology on my Honda pcx as stopped working don't no why does anyone no why please
- ScooteringAbout
Re: honda pcx stop start technology
Your battery may be wearing out, if I understand correctly the PCX has a system to avoid using stop start, if the battery is not charging 100%.
aka DrewJW
Only the new version has that intelligent feature, the 2011 model will let the battery die.
Make sure the handlebar switch is in the correct position and check the seat switch.
When you say stopped working, do you mean your bike does start and ride ok but the idle-stop function does not kick in as usual - or you just have problems starting?
- ScooteringAbout
Ah my bad, didn't notice he had listed his yeargn2 wrote:Only the new version has that intelligent feature, the 2011 model will let the battery die.
aka DrewJW
when I stop at traffic lights it just keeps going wont cut off as normal
- RideLondon
Well, on the bright side - that is the best thing of the two options - better that the bike does work. Hmm, as the slightest tough should start the bike with idle stop engaged, I wonder if the accelerator cable / idle is too tight / too high? Not sure if that is part of how it works.
no the A light isn't on going to buy a new battery but not sure on the dimenions of the battery
Are you absolutely sure you haven't switched it off?
- abcdarko
- Year: 2017 Forza 125
- Color: Grey Black
Also check for the temp sensor, the system doesn't work while engine is cold.The diagnostic tool should show why.
