honda pcx stop start technology
marktilley160
Post by marktilley160 »
the stop start technology on my Honda pcx as stopped working don't no why does anyone no why please
ScooteringAbout
Re: honda pcx stop start technology
Post by ScooteringAbout »
Your battery may be wearing out, if I understand correctly the PCX has a system to avoid using stop start, if the battery is not charging 100%.
aka DrewJW
Only the new version has that intelligent feature, the 2011 model will let the battery die.
Make sure the handlebar switch is in the correct position and check the seat switch.
When you say stopped working, do you mean your bike does start and ride ok but the idle-stop function does not kick in as usual - or you just have problems starting?
ScooteringAbout
gn2 wrote:Only the new version has that intelligent feature, the 2011 model will let the battery die.
Ah my bad, didn't notice he had listed his year :oops:
aka DrewJW
marktilley160
when I stop at traffic lights it just keeps going wont cut off as normal
RideLondon
Post by RideLondon »
Is the 'A' light on?
Well, on the bright side - that is the best thing of the two options - better that the bike does work. Hmm, as the slightest tough should start the bike with idle stop engaged, I wonder if the accelerator cable / idle is too tight / too high? Not sure if that is part of how it works.
marktilley160
no the A light isn't on going to buy a new battery but not sure on the dimenions of the battery
Are you absolutely sure you haven't switched it off?
abcdarko
Year: 2017 Forza 125
Color: Grey Black
Post by abcdarko »
Also check for the temp sensor, the system doesn't work while engine is cold.The diagnostic tool should show why.
