a easy way to fix a Helmet at PCX !!!
sol.like
Year: 2010
Color: black/brown
Post by sol.like »
:D !! u bye a 3mm steel line with PVC between 0.5 and 1.0 m and 4 peace of Aluminium rings to fix the ends to rings.
Sorry my english.
See the pics and you know. The same promoted Honda at user manual bug not can order or bye at thailand so I make at myself and better then I need a longer line to fix my helmet.
2015-01-23 09.57.40.jpg (8.38 KiB) Viewed 2234 times
2015-01-23 09.55.54.jpg (16.54 KiB) Viewed 2234 times
2015-01-23 09.58.44.jpg (12.7 KiB) Viewed 2234 times
sol.like
Year: 2010
Color: black/brown
Re: a easy way to fix a Helmet at PCX !!!
Post by sol.like »
U must press the rings, or I do it wit a hammer then I only hade that!!
sol.like
Year: 2010
Color: black/brown
Post by sol.like »
Here better pics
2015-01-23 10.22.11.jpg (640.53 KiB) Viewed 2229 times
2015-01-23 10.21.26.jpg (763.27 KiB) Viewed 2229 times
2015-01-23 10.23.11.jpg (383.44 KiB) Viewed 2229 times
Chief, I've never seen anything like that
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
Actually, I made more or less the same thing, but I used cable binder clamps. Using a long bit of cable lets me attach the Admiral's helmet as well as my own to the PCX, and leaves the underseat compartment for whatever (hi-vis vests at a minimum). Our helmets don't fit under anyway, so I am always using the Honda-supplied loop thing when I am alone.
I used three feet of cable, and it allows us to put one helmet on one side and the other on the other, nice and neat. I don't think I have a pic, but will try to take one when the season opens up again.
Here is a link to the clamps I am talking about, but they are available at your local hardware store for short money.
http://www.ronshomeandhardware.com/N248 ... oCrGvw_wcB
sol.like
Year: 2010
Color: black/brown
Post by sol.like »
My clamps also specially for cable, but smaller than yours and easier to install. And not make scratches. And your cable I think have same size then mine 3 feet I think be near one meters. And can also fixed 2 helmet or any else, and I used a simple plastic bag for safe rain.
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
Your right, Sol - if I had seen cable clamps like you found, I would have used those. I had to cut off excess threaded post (rotary tool made short work of it though) and do some filing to get the clamps to go through the D-rings of our helmets. And tightening the two little bolts that were so close together was not exactly a picnic either. OTOH - I only had to do it once, so I'm OK.
