This stuff works great
I read about this stuff here, from a forum member...bought a can and have been using it for a few weeks.
It really works great on the windscreen, and everywhere else I've applied it.
Don't put on seat or tires.
Beads the water up after a wash !
(got water in the cup covering the oil pressure switch connection, caused the oil light to register dimly - which should not have happened IMO considering where it is down there on the chassis - perhaps it's been gathering water there for weeks. Removed the cup and wire connector - dried & cleaned things with some fine sandpaper, added a little silicone grease to try to improve the cup seal & protect the connection. The light went out. I maintain that a clean & degreased engine runs cooler, and a clean scooter makes Mr. Honda smile.)
SECoda
Honda Forza 300 &
Honda Forza 300 &
Re: This stuff works great
Post by SECoda »
My Honda dealer pushes this stuff. You can use it anywhere. UV protection as well. Non-aerosol.
Cycle Care Formula 33 Spray and Wipe Polish
https://www.cyclecare.com/index.php?rou ... uct_id=125
http://www.motorcycle-superstore.com/42 ... nd-cleaner
Cycle Care Formula 33, is designed to be used as a quick-fix or touch-up on all surfaces that would normally, or previously be protected by Cycle Care Formula 3, and is great for touring touch-ups. (Note: Previous Formula 3 application not required, but recommended). Formula 33 helps provide protection from UV rays, acid rain, & dirt accummulation. It will also polish and remove bugs, road tar, and road film from your windscreen, paint (clearcoat), and chrome. Formula 33 is non-streaking and will provide protection, as well as provide a water repellent shine, but it will not harm any surface including pin stripping, custom paint, or murals.
•Enhances shedding of rain water from windshields.
•Designed to be used as a quick-fix or touch up on all surfaces. It polishes and removes bugs, road tar, and road film from your windscreen, paint (clearcoat), and chrome.
•It enhances Cycle 3, it is non-streaking and will provide protection, as well as provide a water repellent shine. Spray and Wipe helps provide protection for UV rays, acid rain, & dirt accumulation.
•Cycle 33 will not harm any surface including pin striping, custom paint, or murals.
•Cycle 33 provides effortless dust and dirt removal without fear of scratches.
I was thinking to fog my PCX for winter. I used to use a good fogger on my rotax twin engines in my SeaDoo jet boat and to this date all the hoses and metal in the engine compartment look amazing. Has anyone ever thought to fog the hardware under the cowlings on scooters? Or for that matter just to preserve the new look year round?
Monty1952
Post by Monty1952 »
Cleaning of the windscreen seems next to impossible on the inside. Given that there is hardly any room really impossible to get your hand and cloth down, what do people do to get it clean, if anything?
2014 Forza - Silver 2,300km
2013 BMW C600 Sport 0km!
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Not sure about the Honda but the Givi tall screen fixes that. You can stick your hand easily all of the way down the inside to clean.
Been looking for a magic cleaner to get all the crud off the engine area and wheels - the bikes get a hard life in countries such as the UK with dirty roads and winter.
I've seen people power-wash their PCX and it looked great after, but I thought that would be bad for it due to water getting into places it shouldn't. Do sprays like this get all the crud off of the engine area, or just help keep it clean if it's reasonably clean to start with?
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Monty1952 wrote:Cleaning of the windscreen seems next to impossible on the inside. Given that there is hardly any room really impossible to get your hand and cloth down, what do people do to get it clean, if anything?
I start the corner of a fluffy bath towel down there, grab the end when it comes out and give the screen a back and forth clean.
Steph
Year: 2013 150cc
Color: Black PCX
Post by Steph »
And the screen is very much happy for this. :D
