My Honda dealer pushes this stuff. You can use it anywhere. UV protection as well. Non-aerosol.
Cycle Care Formula 33 Spray and Wipe Polish
https://www.cyclecare.com/index.php?rou ... uct_id=125
http://www.motorcycle-superstore.com/42 ... nd-cleaner
- cyclecare.jpg (53.49 KiB) Viewed 2492 times
Cycle Care Formula 33, is designed to be used as a quick-fix or touch-up on all surfaces that would normally, or previously be protected by Cycle Care Formula 3, and is great for touring touch-ups. (Note: Previous Formula 3 application not required, but recommended). Formula 33 helps provide protection from UV rays, acid rain, & dirt accummulation. It will also polish and remove bugs, road tar, and road film from your windscreen, paint (clearcoat), and chrome. Formula 33 is non-streaking and will provide protection, as well as provide a water repellent shine, but it will not harm any surface including pin stripping, custom paint, or murals.
•Enhances shedding of rain water from windshields.
•Designed to be used as a quick-fix or touch up on all surfaces. It polishes and removes bugs, road tar, and road film from your windscreen, paint (clearcoat), and chrome.
•It enhances Cycle 3, it is non-streaking and will provide protection, as well as provide a water repellent shine. Spray and Wipe helps provide protection for UV rays, acid rain, & dirt accumulation.
•Cycle 33 will not harm any surface including pin striping, custom paint, or murals.
•Cycle 33 provides effortless dust and dirt removal without fear of scratches.
