I installed the below parts in 2020 and was disappointed with no improvement in top speed. I learned that 2019 has a different gear set than older models which is why I didn't see the improvement that others saw. I have 3300 miles on my scooter now with the original belt and parts but top speed is now 66mph and then bounces off the rev limiter.
NCY Variator Assembly (Golden Pulley)
NCY Drive Face (Aluminum)
NCY Roller Weights (20x15)
I see there are a ton of Variator options today but would any of them help with top speed at all? I'm not opposed to swapping gear but has anyone actually done this? I didn't see in the search.
2019 Variator top speed; gear swap?
- Color: gray
Re: 2019 Variator top speed; gear swap?
What size rollers did you install (Gram specific). Did you gain ANY more top end at all? What was your top end before, bone stock?
I have that same exact setup on mine. I immediately saw an extra 7-10MPH top end granted I have a 2017. Get a TTO tach. Helps with tuning the variator.
I run 10.5G sliders in my NCY Variator.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Wirus Win Exhaust
Z-Bars
NCY Variator
