Power command v or bazzaz for pcx?
Aznvthugforlife
I'm all new to pcx, trying to go big bore with fuel management piggyback. I'm just wondering if power commander v or bazzaz can be install on the 2013 pcx stock wiring and connectors? I'd searched google and this entire forum but i can't find an answer.i can dyno map it from scratch if there's no map. Thanks everyone
Re: Power command v or bazzaz for pcx?
I think bazzaz has one,it's a self learning mapping, no need to dyno it. Quite cool but pricey..Aznvthugforlife wrote:I'm all new to pcx, trying to go big bore with fuel management piggyback. I'm just wondering if power commander v or bazzaz can be install on the 2013 pcx stock wiring and connectors? I'd searched google and this entire forum but i can't find an answer.i can dyno map it from scratch if there's no map. Thanks everyone
Aznvthugforlife
Thanks for the quick reply pcxdemon, do you know if their sensor connectors fits stock sensor connects perfectly? Without any wire tapping or cutting. I talked to bazzaz earlier today they said no mapp support pcx and they're not sure if their harness connectors fit pcx model
No biggie if you have to cut a few wires here and there, it's all fairly simple..Aznvthugforlife wrote:Thanks for the quick reply pcxdemon, do you know if their sensor connectors fits stock sensor connects perfectly? Without any wire tapping or cutting. I talked to bazzaz earlier today they said no mapp support pcx and they're not sure if their harness connectors fit pcx model
