I switch original variator to Multivar and also change fixed pulley to malossi ventilvar. It is supplied with 2 different washer for different scooter model assembly. the problem is I am confused with supplied diagram because it look like it was misprinted
anyone can help me?
Help on Multivar
turbojigger
- Year: 2021
- Color: Red/black
Help on Multivar
- ventilvar.jpg (123.05 KiB) Viewed 45797 times
turbojigger
- Year: 2021
- Color: Red/black
Re: Help on Multivar
I put that red arrow to show that line which printed on Malossi's user manual, but I don't know where that line should pointed at
KNguyen
- Year: 22
- Color: red
You put on the outer pulley, then the original washer that was on the scooter, then the two malossi washers, in either order, then the nut.
