Engine light on and Speedo not moving!
wrighty
Color: White fastest!
Post by wrighty »
Hi guys, riding my pcx 125 today (66 plate UK spec) and the engine light has come on plus the speedo isn't moving!
Any ideas??
Cheers.
wrighty
Re: Engine light on and Speedo not moving!
Post by wrighty »
Anyone? Anything I can check??
Have you been guddling in the transmission?
Might have damaged the speed sensor or its wire.
part 11
https://www.bike-parts-honda.com/honda- ... 20/1/38751
Does the speedo sweep round at start-up?
wrighty
Post by wrighty »
gn2 wrote:Have you been guddling in the transmission?
part 11
Not done anything at all to it, weather obviously has been bad recently maybe that has a bearing on it.
The speedo does sweep around on startup yeah, this morning it worked for literally 30secs down the road then nothing!
part 11
Damp?
wrighty
Post by wrighty »
part 11
Damp?
Do you mean the actual sensor? if so quite possibly.
Fixable? Does the rear wheel have to come off to get at the sensor??
I'd be checking and cleaning all connectors between the sensor and the speedo first.
wrighty
Post by wrighty »
Ok, will have a look at that. I did manage to look at the actual sensor and it was a bit wet slightly gritty/dirty.
I've cleaned it up but not run it yet, will report back when i do.
Whilst on topic, how does the wire on the sensor disconnect as i couldn't do it without fearing id break it!
wrighty
Post by wrighty »
Bump.
Ok I've took it apart and checked the wiring especially behind the air box as read on here someone had an issue there but it looked ok all be it a bit twisted but looked fine.
I am checking the connectors at the dash end now but not sure where the speedo sensor one is, does anyone know which it is?
Earlier LED models circa 2013/14 apparently have a single 16-way multi-connector to the dash assembly so either that info is wrong or things have changed - you may find a circuit for newer models searching google.
If you can get them off easily then may be worth doing it, or just waggle them a bit :)
wrighty
Post by wrighty »
iceman wrote:Earlier LED models circa 2013/14 apparently have a single 16-way multi-connector to the dash assembly so either that info is wrong or things have changed - you may find a circuit for newer models searching google.
Done that bit! :D
Mines a 2016 led uk model and I've been looking at the wiring diagram here https://www.hondapcx.org/viewtopic.php?f=15&t=771 but it's giving me a headache!
I may buy a sensor and hope for the best if all this wiggling and cleaning dont work.
wrighty
Post by wrighty »
I've cleaned all the connectors with contact cleaner and wiggled all the wires, swapped the fuses out as well just in case but nothing :cry:
EML light has gone out tho! so that's something, will order a sensor but still not confident it will fix it as heard they rarely if ever go wrong.
That may be an older wiring diagram that you are looking at. You have the LED version.
Try this one.
PCX LED resized.jpg (627.99 KiB) Viewed 13473 times
Mel - still shows one multi-way connector and different colours - just to check, we are talking about the combi meter connector?
Yes, but also be aware of the LED control unit.
If the engine light comes on and it is part of the display, does the bike start? If the bike runs then that eliminates a lot of the wiring. Then you can pull the speedometer and check the connectors on it and to it. However, if everything else on the speedometer assembly works except the meter itself I would be inclined to pull the VS Sensor.
See page 21-17 of the service manual.
Maybe this will help.
vs sensor installation.jpg (145.86 KiB) Viewed 13453 times
vs sensor inspection.jpg (168.07 KiB) Viewed 13454 times
amin12345
Post by amin12345 »
Hi, I am having the same exact issue with my PCX 2016 the engine light is on and the speedometer doesn't work. speedo sweeps round at start-up as normal the engine sounds fine when riding.
suddenly the speedometer works as normal and the check engine light goes away after riding and switching the bike off and on a couple times then it comes back again!
help will be much appreciated.
Sounds like you may have crud in the switches and possibly the speed sensor. The seed sensor is at the back wheel. Check the wires that go into it. Use WD-40 to clean your switches.
amin12345
Post by amin12345 »
Mel46 wrote: Sat Feb 13, 2021 11:20 am Sounds like you may have crud in the switches and possibly the speed sensor. The seed sensor is at the back wheel. Check the wires that go into it. Use WD-40 to clean your switches.
Which switches would I have to clean? I have ordered a new speed sensor. waiting for it to be delivered.
Ill report back if this fixed the issue.
There are multiple switches that are susceptible to weather problems, including the side stand switch and the (depending on where you are) Start/Stop or Idle/Stop...or whatever it is called there. Spray some WD-40 in the switch and move it back and forth multiple times. You really need to take that switch off and check the contacts, but I now how difficult that one is to remove.
