2018 Honda PCX Performance
Re: 2018 Honda PCX Performance
CaliCal, would you please update your profile by changing your PCX model year and Adding your location. You're asking for help from us, we'd like a bit of that from you too.
Below my post you'll find easy directions to get that info entered.
We all thank you in advance. Oh and good luck with your turbo idea. That's a new mod to me! ;)
TheMaverick
Post by TheMaverick »
CaliCal wrote:I removed the snorkel from the air filter
Would that be the "snorkel" that keeps water well away from the engine inlet when the bike is around water?
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
I was waiting for Mav to make a special edition fast PCX for CaliCal. LOL
This is the snorkel he was talking about..(photo Not pcx but it is similar to this)
Tried removing it once but I don't like the snarling sound the scoot is making..
TheMaverick
alx123 wrote:this is the snorkel he was talking about..(photo not pcx but it is similar to this)
Yep - I was just trying to politely say "I really don't think that is a good idea".
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
I'm pretty sure that's to make the air intake process more quiet.
I'm not even sure if we should call it a snorkel at all..
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
The photo above is wrong, my apologies..
the snorkel to be removed is the Part no. 4 in this diagram
Gil
Post by Gil »
springer1 wrote:
Putting their elaborate sales pitch aside, if you send an offset temperature reading to the computer and that changes the air/fuel mixture to be richer, wont that help with performance?
Interesting thought. I had a 150 Stellla 2-Stroke that was setup as new to make emission standards - right on the edge of lean. When I fattened up the main jet, it got noticeable more power while still maintaining a nice plug read. I also had installed a CHT - Cylinder Head Temperature Gauge - and its reading actually showed a slight temp reduction .... until I later on installed a different air filter & exhaust but thats another topic.
Back to the subject - I like fuel economy, but if the PCX is designed right on the edge of lean, and a bit richer would increase the HP with only a slight hit on mileage, I'd want to try it out.
Don't buy that unit though. I have seen people use resistors inline with the temperature sensor. I have never looked into it, but it might be that easy.
Gil
forza300
Post by forza300 »
Loving all the sea-of-the-pants dyno experiments here :)
Going back a few threads, the Vespa has smaller wheels and is lighter (as pointed out) so even with the same HP the engine will rev faster and spin those small wheels faster. I bet you have a little better top speed though on the PCX?
The road is long, and at the end of the day, the only person you are racing, is you.
TheMaverick
springer1 wrote:I had a 150 Stellla 2-Stroke that was setup as new to make emission standards - right on the edge of lean. When I fattened up the main jet, it got noticeable more power while still maintaining a nice plug read. I also had installed a CHT - Cylinder Head Temperature Gauge - and its reading actually showed a slight temp reduction
A temp reduction is normal with a rich mixture - we do the same with petrol aircraft engines on take-off & climbout when they're at full power and airspeed is lower.
springer1
Post by springer1 »
Roger that - thanks. EFI has its significant benefits, but (unlike a carb) a lot of its actual workings are a mystery to me. If there was a simplistic way to fatten the mix just a bit, I'd be interested to learn how it could be done.
springer1
Post by springer1 »
Yes, the PCX has a bit more top end, but more importantly is a far more relaxed because the engine is so nicely balanced, and the larger wheels & better suspension / geometry make running over 55 far less busy. The PCX is so marvelously smooth.
The stock Vespa - Stella 150 2- stroke & 4 speed setup was geared so that the engine really didn't over rev with the 10" wheels. Top speed limitation was more of an issue with wind resistance and horsepower as the engine got on the right side of the power curve at higher speeds. The mid range torque from their 150 2 stoke is very surprising.
But what is really remarkable is their trailing link design. When a bump is encountered by the front suspension, the wheel not only rises, but also pivots back. I think this was originally an aircraft design, works great on these scooters.
Not to mention they carry an extra wheel (carried opposite the engine under the left side cowl) which can quickly be installed if either tire goes flat because both front & back suspensions are single arm /sided.
But time marches forward, I'll stick with the newer PCX - I'm amazed every time I ride it.
Once again, CaliCal, where are you located?
Outside of the United States it is harder to get the NCY variator set outside of the United States.
As I have said in previous threads, the variator set is not just for more top end. It also gives the bike more power to climb hills...well, steep inclines. It will never be a hill climbing dirt bike. However, with the NCY variator set you can keep up with traffic when on streets that start to climb. Consider getting the set.
Gil
Post by Gil »
There are some units that are better and changing the fuel map. One example is the
Bazzaz piggyback fuel controller. I haven't used it, but it looks like it could adjust fuel to one's liking.
It is more tedious than a carb though. They do offer an auto tuning add on for their piggyback computer.
I won't be messing around with engine tuning anytime soon. Stock is just more dependable than it being an Research Development project.
Gil
Gil
Post by Gil »
Mel46 wrote:Once again, CaliCal, where are you located?
I have the NCY variator kit. I had it with 13 gram weights, it worked great, but now with Dr pulley 12g weights. I recommend to at least get the Dr Pulley 12g weights. They helped with acceleration, ~ about the same as the 13g rollers, but most of all helped with lowering the RPM at cruising speed. Before the Dr Pulley slider weights the I felt like I needed to shift up the transmission, which I can't lol. Now the RPM's drop down lower, it makes the scoot feel more relaxed.
Gil
Don't use sliders with the NCY variator. You can use the rollers, but the sliders don't work well with the Teflon coating on the NCY variator and can actually damage it.
There has been a consensus among members of this forum that 13 gram weights are the favored weight for the NCY setup. However, if you have not installed the kit yet, then the 12 gram weights will work quite well. Just changing the weights helps in the takeoff, which I guess is what you are interested in right now.
Heedehcheenuh
Color: Black Metallic
Post by Heedehcheenuh »
My 2015 Honda PCX 150 (K-18) ran 62-63mph on the rev limiter before the NCY variator change. I replaced it with the variator- face-13g rollers and saw the increase up to 70mph (speedometer) 73mph (GPS). I then installed the GIVI short windscreen and Leo Vince exhaust and she moved on up to 73mph (speedometer) but I have yet to check the GPS speed. I am pleased with the out come and may even do the gear change to help lower the rpm. I will so a bigger/taller rear tire also. Right now I am happy and she holds her own even on non busy interstate shots. I plan on keeping the PCX but also looking into another bigger bike/scoot as in the Kymco XTown 300i/Yamaha XMax/Suzuki Burgman 200/Sym CitiCom 300.
Heedehcheenuh
Chuck D
Ride on.....
Metallic Black
Leo Vince GP Corsa Exhaust
NCY Variator Kit and Drive Face with 18g rollers
Givi Windscreen D1136T
2 Wheels Down Head on a Swivel
Gil
Post by Gil »
Heedehcheenuh wrote:My 2015 Honda PCX 150 (K-18) ran 62-63mph on the rev limiter before the NCY variator change. I replaced it with the variator- face-13g rollers and saw the increase up to 70mph (speedometer) 73mph (GPS). I then installed the GIVI short windscreen and Leo Vince exhaust and she moved on up to 73mph (speedometer) but I have yet to check the GPS speed. I am pleased with the out come and may even do the gear change to help lower the rpm. I will so a bigger/taller rear tire also. Right now I am happy and she holds her own even on non busy interstate shots. I plan on keeping the PCX but also looking into another bigger bike/scoot as in the Kymco XTown 300i/Yamaha XMax/Suzuki Burgman 200/Sym CitiCom 300.
Heedehcheenuh
Chuck D
Ride on.....
What model Givi screen is it?
Gil
TheMaverick
Any thoughts on doing a 175cc big bore kit while you're at it?
http://www.yuminashi.com/-pcx150-esp-17 ... ht-bore-k/
Heedehcheenuh
Heedehcheenuh
Chuck D
Ride on.....
Gil
https://www.cyclegear.com/parts/givi-d1 ... -2014-2018
This was the screen I bought.
Heedehcheenuh
Chuck D
Ride on.....
Metallic Black
Heedehcheenuh
I was looking at the kits but not interested in then until this motor is ready to be overhauled. With just over 5k miles on the speddometer that will be some time lol. I may end up looking at the Kymco line first seeing as they are right across the state from me. Kymco USA being in Grenville S.C.
Heedehcheenuh
Chuck D
Ride on.....
p.s. I will plan on keeping the Honda but would like to have the bigger scooter/bike for long or touring rides.
Metallic Black
