New member to the family
Re: New member to the family
MayHem scored the better oil drain bolt, somehow.
- alx123
- Bangkok Rider
- Color: Fast White
And a much cleaner undersidechicaboo wrote:MayHem scored the better oil drain bolt, somehow.
- MayHem
- Year: 2012
Must be Thai only models or 2016 onwards as my 2015 says 153cc on the casingalx123 wrote:No, it isn't a misprint
2012 PCX150 - Red Sold
2015 PCX150 - White
2015 PCX150 - Red
2015 PCX150 - White
2015 PCX150 - Red
Heh chicaboo, why do you say that? Mine eyes can't tell any difference (from my '15). Ah, it's Gotta be me though cause you're good at this stuff
Where's my glasses?
WhiteNoise wrote:Heh chicaboo, why do you say that? Mine eyes can't tell any difference (from my '15). Ah, it's Gotta be me though cause you're good at this stuffWhere's my glasses?
Just below the rear brake cable bracket it says 149 cm3
YouYou, I think WN means he can't see the diff between oil screen access fittings that chickaboo mentions as "a better one". I know what he is saying because when I went looking for the GY6 screen kits I noticed variations too. The flats are wider on some kits but the drive is smaller on others. A good one to me would have the healthiest drive nut... that's all.you you wrote:Just below the rear brake cable bracket it says 149 cm3WhiteNoise wrote:Heh chicaboo, why do you say that? Mine eyes can't tell any difference (from my '15). Ah, it's Gotta be me though cause you're good at this stuffWhere's my glasses?
- screen.jpg (61.24 KiB) Viewed 1607 times
Yep, Homie got it. The nut on MayHem's scoot is deeper and squarer so it's easier and safer to remove.
chicaboo wrote:Yep, Homie got it. The nut on MayHem's scoot is deeper and squarer so it's easier and safer to remove.
It is isn't it. Can anyone get the part number?
- MayHem
- Year: 2012
Ok so went for a ride today with meon the 2015 white and the wife on the 2012 red. Could not believe how much quicker the red pulls away from low speeds and right through to the top which confirmed my suspicions the 2015 is much slower. Mind you my wife is just under 30kgs lighter the difference in acceleration was astounding and I don't believe the weight had a great effect on it. We didn't swap as the white is unregistered and I didn't want her to get caught on it for my pleasure. So I thought the later models just had less top end speed due to a gearing change but it appears to be right the way through.
Maybe I have to do a full motor swap on them before I sell the red one lol..
2015 PCX150 - White
2015 PCX150 - Red
2015 PCX150 - White
2015 PCX150 - Red
^ Ditto ^you you wrote:chicaboo wrote:Yep, Homie got it. The nut on MayHem's scoot is deeper and squarer so it's easier and safer to remove.
- Rickjds
- Year: 2020
- Color: Candy Luster Re
homie wrote:Can someone second this claim please, is this true? Have the 2016/17's PCX150's scaled back to 149cm? Look here if you have a 16....alx123 wrote:The new PCX is even smaller in displacement 149cc compared to the old 153cc.
early 2015 LED PCX150 models where 153cm
From my US 2017 PCX 150
- 2017 filter screen bolt
- IMG_3109.JPG (166.98 KiB) Viewed 1555 times
Dam, you have the nicer oil drain bolt, too.
