New member to the family
chicaboo
Re: New member to the family
Post by chicaboo »
MayHem scored the better oil drain bolt, somehow.
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Post by alx123 »
chicaboo wrote:MayHem scored the better oil drain bolt, somehow.
And a much cleaner underside :D
MayHem
Year: 2012
Post by MayHem »
alx123 wrote:No, it isn't a misprint
Must be Thai only models or 2016 onwards as my 2015 says 153cc on the casing
2012 PCX150 - Red Sold
2015 PCX150 - White
2015 PCX150 - Red
Heh chicaboo, why do you say that? Mine eyes can't tell any difference (from my '15). Ah, it's Gotta be me though cause you're good at this stuff ;) Where's my glasses?
WhiteNoise wrote:Heh chicaboo, why do you say that? Mine eyes can't tell any difference (from my '15). Ah, it's Gotta be me though cause you're good at this stuff ;) Where's my glasses?
Just below the rear brake cable bracket it says 149 cm3
YouYou, I think WN means he can't see the diff between oil screen access fittings that chickaboo mentions as "a better one". I know what he is saying because when I went looking for the GY6 screen kits I noticed variations too. The flats are wider on some kits but the drive is smaller on others. A good one to me would have the healthiest drive nut... that's all.
chicaboo
Post by chicaboo »
Yep, Homie got it. The nut on MayHem's scoot is deeper and squarer so it's easier and safer to remove.
chicaboo wrote:Yep, Homie got it. The nut on MayHem's scoot is deeper and squarer so it's easier and safer to remove.
It is isn't it. Can anyone get the part number?
MayHem
Year: 2012
Post by MayHem »
Ok so went for a ride today with meon the 2015 white and the wife on the 2012 red. Could not believe how much quicker the red pulls away from low speeds and right through to the top which confirmed my suspicions the 2015 is much slower. Mind you my wife is just under 30kgs lighter the difference in acceleration was astounding and I don't believe the weight had a great effect on it. We didn't swap as the white is unregistered and I didn't want her to get caught on it for my pleasure. So I thought the later models just had less top end speed due to a gearing change but it appears to be right the way through.
Maybe I have to do a full motor swap on them before I sell the red one lol..
2015 PCX150 - White
2015 PCX150 - Red
^ Ditto ^
Rickjds
Year: 2020
Color: Candy Luster Re
Post by Rickjds »
homie wrote:
alx123 wrote:The new PCX is even smaller in displacement 149cc compared to the old 153cc.
Can someone second this claim please, is this true? Have the 2016/17's PCX150's scaled back to 149cm? Look here if you have a 16....
early 2015 LED PCX150 models where 153cm
From my US 2017 PCX 150
2017 filter screen bolt
chicaboo
Post by chicaboo »
Dam, you have the nicer oil drain bolt, too.
