Yuminashi 164cc kit (125)
Color: 15 Forza
Post by 87112 »
I am thinking of going with the Yuminashi 164cc kit and running with the stock exhaust. Would this be an OK combination, they suggest aftermarket exhaust but I find the stock PCX exhaust quite good. Not loud at all.
http://www.yuminashi.eu/164cc-essentials-kit-pcx125-v1/
Here is the kit, I am thinking of just buying this only and none of the stuff Yuminashi suggest with it. Think it would be sufficient? I don't ask for much maybe a hr max freeway run at 65mph. And than coming back the city route, just gets real old city ability only all the time.
Thanks for any reply.
:geek:
chicaboo
Post by chicaboo »
You'll overheat badly with a stock exhaust on a BBK!
Oh, the heat that used to come off my radiator when I had a totally stock 150...
This is cheap, looks stock, and sounds amazing:
http://nolimitz-maticshop.com/en/honda- ... da-pcx-150
Buy it or someone will slap you.
That Yuminashi kit will be great, everything you need for a 125 really.
Color: 15 Forza
Post by 87112 »
http://www.ebay.com/itm/Racing-collecto ... SwaB5Xj4lO
Is this exhaust good for the kit?
Trying to find one that does not need the baffles replaced. I know Scorpion exhausts don't need baffles replaced but they don't offer one for the PCX.
:geek:
lolofigo
Year: 2012
Color: Silver
Post by lolofigo »
chicaboo wrote:You'll overheat badly with a stock exhaust on a BBK!
I have 164 yuminashi kit with stock exhaust and it overheats. But it overheats with aftermarket one from webike as well so it's not exhaust fault. I wish I have cut bigger holes in head gasket water ports when I put it on. Too late now. If I have to take the engine apart again I will put 150 head conversion from yuminashi.
lolofigo
Year: 2012
Color: Silver
Post by lolofigo »
87112 wrote:I am thinking of going with the Yuminashi 164cc kit and running with the stock exhaust. Would this be an OK combination, they suggest aftermarket exhaust but I find the stock PCX exhaust quite good. Not loud at all.
Go ahead and get it. It's well worth the money. I have overheating problems with mine but it's head gasket alignment rather than stock exhaust fault.
Color: 15 Forza
Post by 87112 »
Can anyone suggest a aftermarket exhaust. No that does not ever need a baffle change.
So both of you guys are saying that kit for 418.00 dollars is sufficient enough with a aftermarket exhaust.
On the page Yuminashi is suggesting 4 other items which makes it a pain in the ass.
:geek:
lolofigo
Year: 2012
Color: Silver
Post by lolofigo »
87112 wrote:Can anyone suggest a aftermarket exhaust. No that does not ever need a baffle change.
It overheats on WOT if revs go higher when accelerate downhill. It doesn't overheat in traffic or in hot weather. 164 kit does everything on 1/3 throttle that stock would on WOT.
Color: 15 Forza
Post by 87112 »
Sounds like it would make the little PCX125 a pocket rocket.
How many hours does install take for a professional mechanic?
:geek:
lolofigo
Year: 2012
Color: Silver
Post by lolofigo »
87112 wrote:Sounds like it would make the little PCX125 a pocket rocket.
Don't know. It took me two days and few beers. I'm amateur and it's taken more time to take plastics off than actual engine work. Have a go yourself and you might learn something. Great tutorial here on forum from Maddiedog. You'll be happy with the results. Image
Pcxdemon
Post by Pcxdemon »
I'm not a professional...it'll take me 5-6 hours to ride away...
