Which engine oil suits for pcx 150 for the first oil change.
suzxee1234
Color: Blue
Post by suzxee1234 »
I have the following types available in a local shop. Which one should I choose for the initial oil change at 1000km.
easyrider
Color: blk
Re: Which engine oil suits for pcx 150 for the first oil cha
Post by easyrider »
Mobil 1 10-w30 synthetic
I don't know if that answered your question, but the two most important parts of his answer were 10w30, and full synthetic. Because it does not have a wet clutch I don't know that the MA vs MB will make much difference, though I would go with MB because it is recommended.
chicaboo
Post by chicaboo »
The top bottle is just SAE30 constant viscosity (for lawn mowers, etc), so you can rule that one out. Either of the other two would work fine.
Eiron
Color: Poseidon Black
Post by Eiron »
Hi suzxee1234,
Out of those three choices, the Pro Tech Gold 4AT (MB 10W-30 semi-syn) is the best oil for your PCX.
However, if you have access to full syn motor, that would be even better oil for (probably) less money.
An xW-40 or xW-50 weight oil will provide better protection than an xW-30 oil.
suzxee1234
Color: Blue
Thank you all for the help.
I will go with the semi-senthetic option then.
doletotodole
Color: WHITE
Post by doletotodole »
This perpetual question really bothers me and a lot of other scooter drivers in China.
Like me and other scooter lovers, we struggle to find the perfect oil for scooters.
I have with me right now a gold 4AT MB which I purchased from the PCX vendor shipped from Thailand, which is the recommended orignial.
I think the price says all, the gold original costs less than 7 GB Pound and in Thailand much less, half of that I suppose, and this align with common beilef that the original is the bare minimum.
That's why I am think about, after running in, using the Mobil 1 full synthetic MA or Motul scooter MB.
As long as it's a good quality 4 stroke motorcycle oil with the temp rating's for the environment, I doubt the humble PCX engine would notice any difference at all - just don't use 2 stroke oil or treakle and you will be fine, as will the bike.
Color: 15 Forza
Post by 87112 »
I plan on using Quaker State conventional oil. I think conventional oil is just fine for the little 125cc motor. Will just it one riding season.
:geek:
Can't we sticky one of GN2s oil comments?
iceman wrote:As long as it's a good quality 4 stroke motorcycle oil with the temp rating's for the environment, I doubt the humble PCX engine would notice any difference at all - just don't use 2 stroke oil or treakle and you will be fine, as will the bike.
It's treacle, my old treacle.
