After 1500km of ownership (yep, I only ride on weekends and also had a couple months off...) it was time to top the oil up on the scoot.
I bought 1L of Penrite semi synth 10W30 from Repco for $12aud, which I can also use for top ups in the VZR (not that it goes through oil).
And when I got home I realised my funnel is too big for the PCX. Then I remembered I had a Tom Thumb pump for doing transmission fluids.
Luckily, most oil bottles have a standard cap with the same thread, so the Tom Thumb pump just turned right onto my oil bottle without fuss.
I wasted a couple squirts of fresh oil to rinse out the pump and then proceeded to incrementally top up the oil until it was at the top of the mark.
It seems to have only taken about 50mL of oil to bring it up to level, but even with that the idle seemed smoother. Or is that just my imagination?
Anyhow, I know when using a 1L bottle with the correct sized funnel and no exhaust in the way, this is all just "cool story bro" to most people.
But, you can use the Tom Thumb pump on 4/5L oil bottles or with it's own bottle depending on what you want. My TT bottle was full of tranny fluid.
You can buy these pumps without bottles and do what I did, or just solely use one with it's own bottle for your scooter to avoid oil contamination.
I've seen these pumps with different style nozzles from other manufacturers, so depending where you are in the world, the will likely differ slightly.
