Hello everybody.
My PCX 2012 eSP has only 5500km on the tacho. I have open the air filter housing and was supprised that the air filter pretty dirty and oily was... I´ve cleaned it a bit, but would you still replace it?
P.S.
On the filter is written HM KZR TH1. It´s not the actual part number (17210-KZR-600), what is this number???
Thanks
Would you replace this air filter?
Nemesis
- Year: 2012
- after the cleaning
- IMG_1165.jpg (75.86 KiB) Viewed 3320 times
- before
- IMG_1164.jpg (89.36 KiB) Viewed 3320 times
j.d.b.
- Color: red
Re: Would you replace this air filter?
Nope. Lotta life left in it.
Its supposed to be oily, a new one out the packet is oily.
Your filter is probably good for another 15,000km or more.
How did you get it that clean? I thought it was sticky on purpose and hard to get any bits off.
Nemesis
- Year: 2012
Thanks for the help
, I was missing a "reference" of what dirty air filter is. Maybe someone has a photo?
I cleaned it with a good vacuum cleaner, but only from the "dirty"- green side.
Nemesis wrote:Thanks for the help, I was missing a "reference" of what dirty air filter is. Maybe someone has a photo?
Cleaning the air filter is a good idea tbh. Same with car inlet and air conditioning ones. Extendes the service life before replacement.
Cue the pedants and nervous cautioning against it.....
- flyingzonker
Why not just take a soft brush and give it a good going over?Nemesis wrote:Hello everybody.
Thanks
I thought that didn't work as the filter is sticky - which is why they say to replace and not clean it. Seems you can clean it to a good extent if you are careful.flyingzonker wrote:Why not just take a soft brush and give it a good going over?Nemesis wrote:Hello everybody.
My PCX 2012 eSP has only 5500km on the tacho. I have open the air filter housing and was supprised that the air filter pretty dirty and oily was... I´ve cleaned it a bit, but would you still replace it?Thanks
- flyingzonker
Even though it is tacky, you should be able to get a lot of loose gunk to fall off. I don't recall the filter being adhesive.iceman wrote:I thought that didn't work as the filter is sticky - which is why they say to replace and not clean it. Seems you can clean it to a good extent if you are careful.flyingzonker wrote:Why not just take a soft brush and give it a good going over?Nemesis wrote:Hello everybody.
