Opener damper
affeno
Color: red
Opener damper
Post by affeno »
Hello this is my solution of the broken opener damper and it works good
davenowherejones
Color: Silver
Re: Opener damper
Post by davenowherejones »
Looks functional, my seat used to fall down but I think some dirt has got in the strut and now it mostly works.
eidikos
Re: Opener damper
Post by eidikos »
when is fully closed it seems that it will hit the helmet if you put it in the lower position? above the battery?
i ask this because the storage widens where the helmet sits and it seems to me that is going to interfere?
if it doesn't hit the helmet great!
i might be coping your solution:)
affeno
Color: red
Re: Opener damper
Post by affeno »
Hello eidikos I was just and test I have shoei raid2 if I take to the left said it close but it works
montliz44
Year: 2013,2014
Color: red+redder
Re: Opener damper
Post by montliz44 »
Nice work, Affeno!
Did you make that yourself? What was it used for originally?
Love it,
Johnny
eidikos
Re: Opener damper
Post by eidikos »
Thats nice!!!
eidikos
Re: Opener damper
Post by eidikos »
so affeno, is it diy or did you purchase it from somewhere?
affeno
Color: red
Re: Opener damper
Post by affeno »
Hello yes I made it by myself but I think you can buy similar at a hardware store as the picture, it is used for windows or furniture
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Re: Opener damper
Post by GeorgeSK »
While I am currently using "Stick" technology, I have also considered misusing a bit of boating hardware. These hatch springs are used to keep the lid of a nav station up. When you lift the lid, the spring becomes rigid. To close, you push on the side of the spring and it collapses.
https://www.amazon.com/dp/B004XAE4B4/re ... EDHDC5RG3J
davenowherejones
Color: Silver
Re: Opener damper
I have stated somewhere in this forum that my seat used to fall down but now it stays up by itself. My Forza was made in June 2013 and has 26,000 km (16,000 miles) on it.
Does anyone have one made earlier?
Does anyone have more km (miles) ?
So as the Forza gets older what problems can I expect to see in the future?
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Re: Opener damper
Post by GeorgeSK »
The damper is temperature sensitive. Mine will not hold below 60 F. 60-75 F is a maybe, and over 75 F it usually works fine. I complained to the dealer, but they could not find any specific recall notice, and of course on that day it was working fine.
Does anybody know of a specific recall that I could point them too?
dergav
Color: grey
Re: Opener damper
Post by dergav »
the damper has not been designed for use in Scotland then!!!
davenowherejones
Color: Silver
Re: Opener damper
Nor the Wet Coast of Canada most of the time.
affeno
Color: red
Re: Opener damper
Post by affeno »
I live in Thailand and bought my Forza in february 2013 and it have 26000km and this problem started maybe after 1 year but now it works good
eidikos
Re: Opener damper
Post by eidikos »
GeorgeSK wrote:While I am currently using "Stick" technology, I have also considered misusing a bit of boating hardware. These hatch springs are used to keep the lid of a nav station up. When you lift the lid, the spring becomes rigid. To close, you push on the side of the spring and it collapses.
@GeorgeSK this is, in my opinion, a better choice than the one from affeno and i will explain why i think that.
on saturday i went with my wife on a trip with the motorcycle club we are registered in. in the compartment under the seat we had her purse, her jacket and my jacket. we put her stuff in the compartment where the battery is but my jacket wouldn't fit in the top compartment. so i had to lay it so part of it was under the thin space that connects the two.
As it turned out it was too hot to wear the jacket so it stayed there for the whole trip. During the trip i opened the seat 3 or 4 times.
Affeno's solution would most probably catch the jacket and maybe damage it also, but GeorgeSK's solution because its a flexible spring and not rigid aluminium wont catch the jacket but adjust its shape upon closure.
