All that is in the kit for the various bikes it fits. I can almost guarantee you will only need the 4 bolts and washers. Once the old one is off, you will be able to see what you really need to use. If you are worried, go back to the dealer and ask for instructions. Yer no that far away fae Aberdeen :-)
Aye, I ken fit like wi the kits. I think I've fitted it ok now but getting the wee fairing back on between the light and the shiled has been an afa disaster
Although the part numbers are slightly different, I believe the mounting process will be the same.
I found this at Honda's website under PCX accessories. Now you can see IF you mounted yours correctly and print it if you want. Cheers! and please let us know how you like the Honda screen http://powersports.honda.com/documentum ... 36-A00.pdf
Ok, I got the fitting correct using the correct bolts, washers and nuts after a number of attempts. Although what I didn't do was move the mirrors. I have the mirror brackets and to be honest, had not idea what they were for......What is the reason for moving the mirrors???
I took her out for a 40 mile blast, the buffeting on the body has all but disappeared and I've got about about another 4 to 5 mph on the top end but the noise around the crash helmet has increased. I don't know if its because its quite a breezy day but I feel that the bike seems to be feeling the cross winds a lot more with the new screen on.
FullSizeRender (2).jpg (40.53 KiB) Viewed 4773 times
FullSizeRender (3).jpg (50.44 KiB) Viewed 4773 times
FullSizeRender (1).jpg (45.55 KiB) Viewed 4773 times
Aberdeen Scoot wrote:Cheers White Noise......Very interesting indeed.
Aberdeen where are ya? Any more opinions on the screen? Are your mirrors or brake levers hitting the screen when you turn the handlebar full left or right? That might be a concern. What say ye? Also whilst riding, are your eyes just above the screen or are you looking through it? Come back please
I just put on on my 2015. You do use all the pieces in the kit. You are essentially putting the new brackets on the plastic shield first (with the windshield on a table or the floor), then when you have it upright, you have 4 bolt holes that line back up with the original 4 you started out with. The new brackets "lift" the windshield away from the scooter about 1'4" to 1/2" inch.
It turned out not to be as big a deal as it first looked when I started out.
