Tire contact with the road
- wangsuda
The recommended tire pressure seemed a bit low to me, due to the amount of weight my PCX carries (me at 110 kg, my son at 35 kg, and 10 kg of gear). The contact patch ran all the way to the side grooves. I upped the pressure a bit and I think I have a good contact patch. Please, opinions and advice are welcome if I have it wrong!
Front tire: Rear tire:
Re: Tire contact with the road
I backed off the recommended pressure about 3 pounds with the larger Michelin's for comfort and grip. This photo was taken at a point I had just leaned into a turn and scraped the ground to see how much tire is never used and does not reflect what you are showing... straight and level on a chalky road?
I might have to try that to see where I'm at with rubber contact 3-4 pounds under.
- wear.jpg (176.5 KiB) Viewed 3045 times
- wangsuda
Ya, I am straight and level and fully loaded. Actually, it's cement dust LOL And I have not backed off. It is upped a bit (41 lbs rear, 38 lbs front).
41 rear 33 front is the recommended for mine. Currently lowered to 38 rear 29 front.
You want to match your surface contact to a tread pattern? With all the patterns available I had not heard of this as a consideration for tire wear control. When I was high and tight I benched mine for performance but then backed down the air pressure because I was not feeling safe in the turns given a little gravel or other seasonal debris one might encounter. Please don't join the survivors list with hard slippery tires
What is the blue object next to the band aid? Looks like a rain gauge
I LIKE your choice of PCX color! Gun metal looks good, we get none of that here in the US.
- wangsuda
It holds my road tax/registration paper. Must be visible. Same for cars too.homie wrote:What is the blue object next to the band aid?
Yep cars need to be visible.wangsuda wrote:It holds my road tax/registration paper. Must be visible. Same for cars too.homie wrote:What is the blue object next to the band aid?
Absolutely no appreciation for design and symmetry when it comes to vehicles. You mean to say not only does a new rider have to display a billboard on his wheels front and back in addition you hang paperwork in a tube?wangsuda wrote:It holds my road tax/registration paper. Must be visible. Same for cars too.homie wrote:What is the blue object next to the band aid?
You know if ever government successfully pulled off something that ugly over here it would be tantamount to making firearms illegal to the general public. We simply would not comply. There wouldn't be enough prisons on the planet or liberal politicians left breathing to enforce such an overwhelming feeling of a government out of control. Much like our current administration which has paved the way for a massive up rise in more informed voters next year... AGAIN!
- wangsuda
Just a rear license plate . . . and there are alternatives to the tube. You can tape the piece of paper on to an outer panel of the PCX LOLhomie wrote:Absolutely no appreciation for design and symmetry when it comes to vehicles. You mean to say not only does a new rider have to display a billboard on his wheels front and back in addition you hang paperwork in a tube?wangsuda wrote:It holds my road tax/registration paper. Must be visible. Same for cars too.homie wrote:What is the blue object next to the band aid?
We have gangs that might object to disfiguring their motorcycles
- gansters.jpg (188.92 KiB) Viewed 2978 times
Your owner's manual will tell you the proper tire psi for normal and max loads.
You must be at max loads at that weight.
Honda engineers have worked all of this out for you.......they built your scooter.
- Bash On!
Doing a happy dance here in Texas. New law does away with the ugly inspection sticker and combines it with the tag registration.
Motorcycle dealers here would be tricky. They did the initial inspection and used a big 'ol plastic tag frame with their advertising to also attach the inspection sticker to. New law = no more ugly plastic frames.
2013 Silver Wing ABS (Black)
1971 BMW R75/5 (White)
YAY TEXAS! best state in the union... if only it didn't get so hot, and the fence was a little higher
I use a lot more tire than that.
I should take a picture, my tires are scrubbed almost the whole way to the edge.
- Bash On!
Using sandpaper on your tires doesn't count.maddiedog wrote:I use a lot more tire than that.
You must have removed your center stand because that is the limitermaddiedog wrote:I use a lot more tire than that.
My centerstand is long gone. The 2011s had issues with the centerstand, so I took mine off. I have leaned enough that my body panels have touched down.homie wrote:You must have removed your center stand because that is the limiteror the brand tire you have is different than Michelin.
I have Dunlops in the rear, stock IRC up front.
Bash On! wrote:Using sandpaper on your tires doesn't count.
maddiedog wrote:
My centerstand is long gone. The 2011s had issues with the centerstand, so I took mine off. I have leaned enough that my body panels have touched down.![]()
That must have hurt
