Battery flat - help!
Re: Battery flat - help!
isn't that a good reason to leave the 'kill' feature? Better be safe than sorry.
- pcxpower
Yes, it is, and it's a really good safety feature
Perhaps in the PCX, which starts so seamlessly, I will try to leave the system engaged, to see if I get used to it...
2015 Honda PCX 125
Hi, I left my keys in my ignition for an hour and a half the other day and the battery went flat as the headlights were left on. I then connected it to my car with jump leads and although the lights are coming when you press the ignition button (with break clutched and kick stand up) there is no response what so ever.
Could I have possibly killed the battery when I connected it to my car, I've read on here that you're not supposed to have the car running, only switched on..?
There is no clicking or any sound whatsoever when I press the button .
Thanks
Thanks
- MikeP
- Color: White /red
Hmm...
Check the Kill switch.
Where's the kill switch...?
- MikeP
- Color: White /red
Its the red switch on the right handlebar, above the start switch.
- image.jpg (77.38 KiB) Viewed 2107 times
Unfortunately my scooter doesn't have one.. (There anyway)
- MikeP
- Color: White /red
Yikes! My Canadian model does!
To my knowledge all bikes have a kill switch. Reason being if there is an accident and the bike is still running, its a simple way to shut off the engine.
Do you have a manual handy, there must be a kill switch.
Buy the way where are you located?
Located in the uk
Will have a dig around for the manual, but I think I might need a new battery/ need to remove the battery and charge it over night?
- MikeP
- Color: White /red
UK
Your great!
I use a battery tender to charge my battery. No need to remove to charge it.
But I cant help thinking there is a kill switch somewhere. Your symptoms are the same as when I accidentally hit mine and try to start the bike. Good luck Friend please keep me posted. I might learn something.
- DAB
Did you have the side stand down when you tried to start, it's been done before.Gepw wrote:Hi, I left my keys in my ignition for an hour and a half the other day and the battery went flat as the headlights were left on. I then connected it to my car with jump leads and although the lights are coming when you press the ignition button (with break clutched and kick stand up) there is no response what so ever.
Thanks
No kill switch on UK models, stop/go only.
Other rides
Nope, kick stand up. Think I must have ruined the battery.
