Battery flat - help!
Re: Battery flat - help!
isn't that a good reason to leave the 'kill' feature? Better be safe than sorry.
pcxpower
Post by pcxpower »
Yes, it is, and it's a really good safety feature ;)
Perhaps in the PCX, which starts so seamlessly, I will try to leave the system engaged, to see if I get used to it... 8)
2015 Honda PCX 125
Gepw
Year: 2010
Color: Grey
Post by Gepw »
Hi, I left my keys in my ignition for an hour and a half the other day and the battery went flat as the headlights were left on. I then connected it to my car with jump leads and although the lights are coming when you press the ignition button (with break clutched and kick stand up) there is no response what so ever.
Could I have possibly killed the battery when I connected it to my car, I've read on here that you're not supposed to have the car running, only switched on..?
There is no clicking or any sound whatsoever when I press the button .
Thanks
MikeP
Color: White /red
Post by MikeP »
Hmm...
Check the Kill switch.
Gepw
Year: 2010
Color: Grey
Post by Gepw »
Where's the kill switch...?
MikeP
Color: White /red
Post by MikeP »
Its the red switch on the right handlebar, above the start switch.
Gepw
Year: 2010
Color: Grey
Post by Gepw »
Unfortunately my scooter doesn't have one.. (There anyway)
MikeP
Color: White /red
Post by MikeP »
Yikes! My Canadian model does!
To my knowledge all bikes have a kill switch. Reason being if there is an accident and the bike is still running, its a simple way to shut off the engine.
Do you have a manual handy, there must be a kill switch.
Buy the way where are you located?
Gepw
Year: 2010
Color: Grey
Post by Gepw »
Located in the uk
Will have a dig around for the manual, but I think I might need a new battery/ need to remove the battery and charge it over night?
MikeP
Color: White /red
Post by MikeP »
UK :D Your great!
I use a battery tender to charge my battery. No need to remove to charge it.
But I cant help thinking there is a kill switch somewhere. Your symptoms are the same as when I accidentally hit mine and try to start the bike. Good luck Friend please keep me posted. I might learn something. :lol:
DAB
Post by DAB »
Gepw wrote:Hi, I left my keys in my ignition for an hour and a half the other day and the battery went flat as the headlights were left on. I then connected it to my car with jump leads and although the lights are coming when you press the ignition button (with break clutched and kick stand up) there is no response what so ever.
Thanks
Did you have the side stand down when you tried to start, it's been done before.
No kill switch on UK models, stop/go only.
Other rides
Gepw
Year: 2010
Color: Grey
Post by Gepw »
Nope, kick stand up. Think I must have ruined the battery.
