Special clutch and outer clutch bell
hi, had any one ever use this parts?
- kc-pk05-400.jpg (29.16 KiB) Viewed 13115 times
- 07172216_51e699190822a.jpg (173.1 KiB) Viewed 13116 times
Mgalutia88
- Year: 2013 PCX 150
Re: Special clutch and outer clutch bell
If anyone, talk to Pcxdemon about clutches.
Mgalutia88 wrote:If anyone, talk to Pcxdemon about clutches.
It'll still be a clutch though...
The bell is about 200g lighter than any other bell on the market...on mine when it's installed I feel like I get a instant shove from behind kinda response when I wot at midrange, I just couldn't replicate that with normal weight bell, so I have to say there is something positive in it..nahojj wrote:hi, had any one ever use this parts?
With clutches wise, you could just easily buy stiffer springs and it'll most likely have very same performance as an aftermarket clutch..
Where is gn2. He likes a good bell end....Pcxdemon wrote:The bell is about 200g lighter than any other bell on the market...on mine when it's installed I feel like I get a instant shove from behind kinda response when I wot at midrange, I just couldn't replicate that with normal weight bell, so I have to say there is something positive in it..nahojj wrote:hi, had any one ever use this parts?
Who is gn2?
what is gn2?
- Alibally
Another forum member. Not so keen on aftermarket tuning parts it's been rumoured.nahojj wrote:what is gn2?
- chainsaw
- Year: 2013 150esp
- Color: white/carbon
I once heard that GN2's entire family was murdered by a street gang riding modified scooters
Ive been using this bell for a couple of weeks now and i have to say its ok but only for track racing. Top end speeds will drop due to torque loss and also i felt hill climbing speeds were dropping to fast as well.nahojj wrote:hi, had any one ever use this parts?
For everyday rider its not really worth it.
Also Yuminashi Inertia weight is deff worth while upgrade,especially for those wanting high speeds on the highways,that thing really helps you achieve and maintain high speeds but also with climbing hills as well..
