Embarrasing: Clock adjustment
heinz57g
Post by heinz57g »
have a DYLAN 150 2007 (was told same/similar as a PCX 150?) for loan, the
entire summer - so far loved every minute of it.
one embarrasing thing though: cannot seem to adjust the clock! and its is a
stupid 8 hours off ...
has a digital display odo/trip meter, underneath the clock (and supposedly the
oil change warning if needed).
and a reset button next to it - but whatever i do, it just resets the trip meter.
any quick tip or instructions? the actual owner is 12000km away, and on the
phone simply could not remember how it was done. his manual is 'somewhere' ...
greetings - heinz -
Re: Embarrasing: Clock adjustment
Page 25 pf the Forza manual has the clock setting method, its Page 28 of this .pdf https://docs.google.com/file/d/0BwmYWlz ... view?pli=1
heinz57g
Post by heinz57g »
tks, but the FORZA seems a totally different model, with two (mode and reset) buttons, whereas mine has only a single button.
greets - heinz -
I just looked up that particular bike. The advertisement said it had a price of $6400. That is ridiculous! The pcx is only $3449 and it has the same engine! AND it looks better than the Dylan.
The Dylan is an old model, no longer available so the price is irrelevant.
heinz57g
Post by heinz57g »
what, please, does this (price?) have to do with setting the clock?
greetings - heinz -
heinz57g
Post by heinz57g »
nobody around here with a DYLAN 150 - or the memory of it?
greetings - heinz -
buddy1976
Post by buddy1976 »
Its been years but if my memory serves me right I think you just press and hold the button for about 15 seconds,if that doesn't work I'll see if I can find the user manual this weekend it's buried at the back of my garage so let me know if you have sorted it out.
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
heinz57g
Post by heinz57g »
no havent figured it out - so if you have a chance at your garage, more than appreciated.
greetings - heinz
buddy1976
Post by buddy1976 »
Hi heinz57g,
Unfortunately I have had no joy in finding the user manual, I can't even find one online which is strange as I used to just Google honda Dylan 125 owners manual and use one of the top results but this no longer works! The only thing I can recommend is maybe calling a few Honda dealers to see if they can advise, I'm sure one can help you it did used to be one of the most popular scooters of its time!
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Hi heinz, I have a 2015 PCX. I have never met a Dylan150, but I will tell you what my owner's manual states for setting my clock. Here ya go:
"To Set the Clock" >>>> Note: You may want to print this IF helpful ;)
1) Turn the ignition switch on.
2) With odometer displayed, press and hold the mode switch until the clock digits start "flashing."
3) Press the mode switch until the desired time is displayed.
> The time is advanced by one minute, each time the switch is pressed.
> The time is advanced by ten minutes, when the switch is pressed and held.
4) Wait for 5 seconds and press mode switch. The clock is set.
> The time can also be set by turning the ignition switch off.
Hope that helped you out, and welcome aboard! :P
heinz57g
Post by heinz57g »
buddy1976, why does that sound like ME looking for something in MY garage?
dealers, little chance, i am travelling greece and southern bulgaria at the moment, and the dealers i found have (and are interested in) newer models only - a DYLAN for them is antique.
whitenoise, tks a lot - sounds logical, will this weekend. after the first line of (3), when the diresed time is diplayed, i assume you would need to wait a few seconds before the actual setting. otherwise, it would just turn over into other modes, right?
greetings - heinz -
:? Don't know heinz, sorry. I haven't set my 2015 clock yet. My dealer did it in the store before delivering my scoot. I was trying to quickly help you by typing what my PCX owner's manual said. I'm betting that as you perform each step your questions will be answered and magically, your clock will read the proper time! :P
All clocks/watches seem to flash today while being set, I usually guess and play with buttons as I go.
Is it just me? I miss the tick tock sound, and wind you watch days. Change is Not Always good, in mine eyes :geek:
"Time" to Go....rider safe heinz 8)
I am guessing that because it is a digital clock it will reset to 12:00 when the power has been disconnected. If all else fails, disconnect the battery and connect it again at noon ... or midnight if you prefer. ;) Desperate needs call for desperate actions. :D
Try looking at some of the manuals here:
http://www.hondampe.com.au/repository/o ... ooter.aspx
and there is some info for a mode + reset clock change in this (similar perhaps to the dylan) page 28
http://campaigns.hondampe.com.au/Motorc ... S250EX.pdf
basically holding the mode+reset buttons in for several seconds then using the mode + reset to change and set the hours and minutes.
DeadInside1969
Post by DeadInside1969 »
Thank you guys, I was too lazy to read the manual but holding the button down waiting 5 seconds and pushing the button again worked.
2015-06-10 19.38.03.png (1.31 MiB) Viewed 14140 times
Live like each day is your last, because you never know.
jmaines
Post by jmaines »
I just ran into this problem with a 2015 PCX, because the clock was not set right and the dealer forgot to include the manual on delivery. When I held the button down, the clock would NOT start flashing, but it switched miles over to kilometers, which is not good because I am in the U.S.
The PCX has a single button, not two like mentioned above for the Forsa. The trick was to push the button twice, then hold it down, and the clock started flashing and I could change then time by holding the button down. Then to get back to the kilometer/miles problem, I pushed the button twice again, and then pushing it down made that change.
