Throttle body neck
- Urbanfreestyle
- Year: 2014 (UK)
Re: Throttle body neck
Wow! Thanks for the info! Do you have any pictures?
Honda PCX 125 ESP (Black)
Mgalutia88
- Year: 2013 PCX 150
I'll try and get some posted today. I'm riding instead of driving so I'll take some pictures after class.
- Urbanfreestyle
- Year: 2014 (UK)
Awesome! thanks! In the mean time i'm looking at getting a stubby backbox, cutting the original one off and clamping the new one on!
Mgalutia88
Here is the back side of the airbox and the washers I used on the airbox as spacers to clear the rear tire.
- image.jpg (23.5 KiB) Viewed 3357 times
- image.jpg (26.17 KiB) Viewed 3357 times
- Urbanfreestyle
- Year: 2014 (UK)
Awesome! thanks for that! how does it sound?
Mgalutia88
its a louder growl as opposed to stock and you get a harmonic vibration from 5700-6300 rpm!
- Urbanfreestyle
- Year: 2014 (UK)
What's a Harmonic Vibration? lol
Mgalutia88
At a certain frequency there is a vibration.
- Alibally
Fit a harmonic vibration damper then.
Here is one attached to an exhaust.
- ImageUploadedByTapatalkHD1404495875.946841.jpg (78.88 KiB) Viewed 3326 times
Alibally wrote:Fit a harmonic vibration damper then.
Harmonic vibration damper = weight
I want a space harmonic vibration damper!!
Or a low calory one
Or maybe just a weight....
Mgalutia88
Good idea. I'll have to think on that one a bit.
- Urbanfreestyle
- Year: 2014 (UK)
SO i tried to fit it but i didn't go as planned, (the pipe is at the wrong angle
can anyone help with this?
This is hands down funniest read, ripe with sexual overtones, lost it at the peanut part ROFL, still laughing too funny... FAIL! un-install forum
Mgalutia88
Cut a few slices the width of your saw blade in the pipe an bend it over then take it to an exhaust shop to weld it up.
there was box vibration but the pipe didn't fit so I had to put a bend on it, you boys need to get a wifeMgalutia88 wrote:Cut a few slices the width of your saw blade in the pipe an bend it over then take it to an exhaust shop to weld it up.
