V4 TRV
Posts: 169 Joined: Wed Oct 31, 2012 5:33 am
Post
by V4 TRV » Wed May 07, 2014 1:09 pm
Is anyone finding difficulties with their ignition key sticking in the barrel?
Mine has happened a couple of times and the key seems to be jammed and only by a little gentle manipulation will it move forward or backwards.
Other than a spray of wd40 I really can't think of any solution for it
Alibally
Posts: 1761 Joined: Thu Nov 03, 2011 5:47 pm
Post
by Alibally » Wed May 07, 2014 1:23 pm
You could use wd40 but it can collect dirt and make it worse. Locksmiths recommend a dry graphite powder. A spray is available in maplin.
It's best not to be too liberal with it though as it might get into the electrical part if the switch.
If it's a forsa you have gn2 was saying his was sticking as well. Maybe there's a issue with them.
Posts: 7767 Joined: Tue Dec 06, 2011 7:54 pm
Post
by gn2 » Wed May 07, 2014 2:14 pm
Mine has occasionally been stiff but wd40 fixed it.
Posts: 8784 Joined: Mon Nov 07, 2011 11:15 pm
Post
by WhiteNoise » Wed May 07, 2014 3:38 pm
Posts: 10000 Joined: Sat Jun 30, 2012 5:37 pm
Post
by you you » Wed May 07, 2014 4:07 pm
gn2 wrote: Mine has occasionally been stiff but wd40 fixed it.
Pfft gumph frrrt hehe
willajabir
Posts: 320 Joined: Mon Nov 25, 2013 6:41 pm
Post
by willajabir » Wed May 07, 2014 10:43 pm
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
Post
by gn2 » Thu May 08, 2014 3:23 am
It gets stiff quite regularly, when wd40 doesn't do the trick my wife fixes it for me.
She knows all kinds of tricks to take the stiffness away.
Slickvic
Posts: 329 Joined: Sun Sep 30, 2012 9:03 am
Post
by Slickvic » Thu May 08, 2014 6:00 am
Mine would sometimes stick to the first position (fuel door/seat) when turning it. I tried oiling the lock cylinder but what really worked was to use a wire wheel machine at work to de-burr the key.
10-20 seconds was all it needed.
Current - 2015 Honda CBR650F
Posts: 2857 Joined: Sun Dec 29, 2013 11:43 pm
Post
by iceman » Thu May 08, 2014 8:14 am
The new 2014 PCX has new keys (according to the deaker) - not sure what the difference is or what the original looked like.
Post
by WhiteNoise » Thu May 08, 2014 8:42 am
Slickvic wrote: Mine would sometimes stick to the first position (fuel door/seat) when turning it. I tried oiling the lock cylinder but what really worked was to use a wire wheel machine at work to de-burr the key.
look to the obvious. I missed that one. Easy fix.
V4 TRV
Post
by V4 TRV » Sun May 18, 2014 7:12 am
Got some of the powder and it works a treat - thanks for the link!
