De-modded from NCY Variator to kinda stock...my thoughts.
Re: De-modded from NCY Variator to kinda stock...my thoughts
Im doing 60-65mph on the flats. Then up hill i'm hitting 55-60. The bike is all stock for now. and just hit 3k miles as of yesterday, we rode all over San Diego.
- Year: 2013 PCX 150
From experience guys here are several things to remember about the NCY variator. First, the stock belt is good for 1000-1200 miles before you loose a good bit of speed. Second, about the same time you will have significant degradation of the Teflon coating in the variator and you will also have a buildup to clean off. Automotive scotch pads are great for this. Third, the Teflon coating in he variator is not compatible with dr pulley sliders. You will loose 10-15mph with swapping in identical weight sliders. The materials grip each other.
I loved the ncy's performance, it just didn't last long in he scheme of things.
Mgalutia88,
What do you think about stripping out the coating, and just giving everything a mirror polish? Also the rule of thumb with the silders is to go down 2oz from the current roller weights you’re using.
Mgalutia88 wrote:From experience guys here are several things to remember about the NCY variator. First, the stock belt is good for 1000-1200 miles before you loose a good bit of speed. Second, about the same time you will have significant degradation of the Teflon coating in the variator and you will also have a buildup to clean off. Automotive scotch pads are great for this. Third, the Teflon coating in he variator is not compatible with dr pulley sliders. You will loose 10-15mph with swapping in identical weight sliders. The materials grip each other.
Did he factor in scotchguard pads and any kind of surface coating?
- ScooterMan
Order up the NCY variator for approx $60, purchase a new belt, and bring it over to my place if you need to and we can swapdem0nk1d wrote:Im doing 60-65mph on the flats. Then up hill i'm hitting 55-60. The bike is all stock for now. and just hit 3k miles as of yesterday, we rode all over San Diego.
it all out in about 15 minutes. =)
2015 PCX 150 (White)[/color]
Mgalutia88 wrote:Look at the NCY kit with drive face here.
http://www.jiangwayne.com/scooter/p_i.php?i=205
Thanks for your order
Your payment of $114.90 USD is complete.
You're now going back to jiangwayne.com inc. Taiwan.
Don't see any difference from stock but...
waspmike wrote:Don't see any difference from stock but...
The charm of the snake oil has you?
This was my first mod and it allowed me to run 73-75mph on flats and 77mph down hill. Very economical upgrade.
Looks like you went with 12g rollers. Mine came in yesterday and installed the 15gram rollers. Performance has been lost due to the weight. When i get back home i'll swap over to the 12gram rollers. However this morning down hill i hit about 75mph.Mgalutia88 wrote:This was my first mod and it allowed me to run 73-75mph on flats and 77mph down hill. Very economical upgrade.
Sorry i meant to say 13grams the rollers are 20x15mm. So maybe that's where i got the 15grams. My bad.dem0nk1d wrote:Looks like you went with 12g rollers. Mine came in yesterday and installed the 15gram rollers. Performance has been lost due to the weight. When i get back home i'll swap over to the 12gram rollers. However this morning down hill i hit about 75mph.Mgalutia88 wrote:This was my first mod and it allowed me to run 73-75mph on flats and 77mph down hill. Very economical upgrade.
- ScooterMan
Sounds like you're getting about what I get. A new belt will get you to the 79mph I'm getting. Also, depending on how much your rear tire is worn may contribute to a loss in ultimate top speed. Glad you're liking it. I just picked up a 2nd PCX150, may do the NCY variator on that too, except that I really don't need 2 scooters! It was just too cheap to pass up @ $2,300 with only 16 miles in perfect cond.dem0nk1d wrote:Sorry i meant to say 13grams the rollers are 20x15mm. So maybe that's where i got the 15grams. My bad.dem0nk1d wrote:Looks like you went with 12g rollers. Mine came in yesterday and installed the 15gram rollers. Performance has been lost due to the weight. When i get back home i'll swap over to the 12gram rollers. However this morning down hill i hit about 75mph.Mgalutia88 wrote:This was my first mod and it allowed me to run 73-75mph on flats and 77mph down hill. Very economical upgrade.
- ScooterMan
Of course, even cheaper would be to just pick up some DR Pulley sliders and use the stock variator on my 2nd PCX. Except, not sure what weight sliders to use. Thinking if each weight change (+1g) adds 3mph top speed, and stock is 12g, then maybe 15g sliders. I'm only 150lbs, so I can give up some accel to gain the top speed. THing is, I already know the NCY variator kit with the OEM honda rollers works perfectly and gets me 79mph...so, it's hard to argue with that. Plus, sliders shipped are at least $40, and the variator kit which I know what it will do for me, is not much more!
Conventional wisdom says 10% lighter with DrPulley sliders so 11 g. But if acceleration is not an issue then stick with stock, 12g.
