Supporting scoot while removing front wheel
Lingwood
Year: 2012
Post by Lingwood »
Hi all
Quick question, what's the best way to support the PCX to enable the front wheel to be removed, considering the belly-pan is plastic and may crumple if placed on blocks?
Cheers :)
Re: Supporting scoot while removing front wheel
I used an old car battery under the forks.
chucktuna
I'm up to 12 or 13 now...
Post by chucktuna »
I just put a towel on a floor jack and lift it up gently. The plastic will push up just until the frame id contacted, No permanent damage.
Lingwood
Year: 2012
Post by Lingwood »
Two good ideas so far, cheers :)
I see from your pic Chucktuna that with the lower body panels removed, there is a frame tube that could be supported with an axle stand?
Pcx Racing
Post by Pcx Racing »
for the better is the scooter on the center stand and a crik wheeler scooter under the
chucktuna
Post by chucktuna »
Pcx Racing wrote:for the better is the scooter on the center stand and a crik wheeler scooter under the
Yes,
It goes without saying that the majority of the weight should be supported by the center stand.
Whatever you use the hold up the front end would only have a few pounds on it.
In fact, a well secured weight on the rear of the seat, or under the seat could act as a counterbalance and let the front hang free.
I used a floor jack for mine>
Mgalutia88
Year: 2013 PCX 150
Post by Mgalutia88 »
Put a wood block on your jack and lift up from the front of the pan while your on the center stand. Run the block or 2x4 scrap perpendicular to the bike across the bottom. This will disperse the weight. Throw a microfiber rag across the piece of wood to protect the paint.
Alibally
Post by Alibally »
Mgalutia88 wrote:Put a wood block on your jack and lift up from the front of the pan while your on the center stand. Run the block or 2x4 scrap perpendicular to the bike across the bottom. This will disperse the weight. Throw a microfiber rag across the piece of wood to protect the paint.
Exactly what I do. It pivots on the centerstand very easily.
I cheat. I have an I-beam in my basement that goes the length of it and helps hold up the house. I can just throw a rope over it and attach the ends to the handle bars.
Mgalutia88
Year: 2013 PCX 150
I'll have to try that one Mel. Thx for the idea ;)
Mel46 wrote:I cheat. I have an I-beam in my basement that goes the length of it and helps hold up the house. I can just throw a rope over it and attach the ends to the handle bars.
I would love a basement. It's one of my tick off things before I shuffle of my mortal coil
The "rec room" from Tremors would be good :D
chainsaw
Year: 2013 150esp
Color: white/carbon
Post by chainsaw »
I do something similar and use a ratchet strap over the garage roller door support bracket
This is what I do. The I-beam in my basement has an ATV winch on it, and I just crank the front end into the air. :lol:
