Clutch nut
Clutch nut
Today I did my 15,000 mile service.
All was going well till I got to the rear drive belt pulley.
Due to the particularly shite design of the casing and cover, the clutch has to come off to get the belt out from the rear pulley.
Unfortunately I can't get the clutch nut off.
Its part 23 in this diagram.
I made a holder for the variator which worked fine but when I tried it on the clutch, nothing doing.
I tried a strap wrench round the outside of the clutch body to hold it, but it just slipped.
Any suggestions for a better tool I could use?
Alibally
Clutch nut
Post by Alibally »
Look at the manual they use a fancy looking strap wrench. It's only tightened to 49nm you know what's it like. Things are sometime tighter to remove than they should be. If I was at work I would use an air gun. It says not to hold it with the brake or rear wheel or the transmission could be damaged.
A strap wrench and a tool in the holes similar to the clutch holding tool and an extra pair of hand would help probably.
ImageUploadedByTapatalk HD1370894794.209839.jpg (207.47 KiB) Viewed 5123 times
Alibally
Clutch nut
Post by Alibally »
Here's an idea. If you have a bit of emery/sand paper cut a strip and fold it in half length way. Wrap it around the clutch drum and try the strap wrench. It might just give it a bit of extra bite to stop it slipping. I use a similar trick when flaring steel brake pipes to fit joining pieces except I use valve grinding paste to stop the pipe moving in the tool.
ben
Re: Clutch nut
Post by ben »
I got a 12v impact driver for this but haven't tried it yet...
Interested in what your going to do for your service, im at the same mileage. Ive got some new rollers ready and was thinking about a new belt, it doesnt need it but im down to an indicated 59mph and think i would get some back with a new belt and makes sense to do it at the same time as the rollers.
Re: Clutch nut
Very helpful Alibally, cheers!
The strap wrench I have is probably too small for the bell's diameter, if the emery paper trick doesn't work I'll have to get another tool.
Have seen various chain wrenches and variator holders on ebay which might suit.
@ben, My belt has cracks between the teeth so it will definitely be getting changed.
I've checked the valves, changed the oil and sparkplug.
Just the drive belt and rollers to change and the jobs a goodun.
ben
Re: Clutch nut
Post by ben »
What weight rollers are you using? I got some 20x15 14.75g from the depths of eBay...hopefully they will work.
Worst part of servicing your own vehicles is finding you dont have the right tool you need, then its the 'do i pay double price at a local shop now or wait for cheap online tool to be delivered'. Sure buy the time im 50 ill have all the toys i need to do anything!
Re: Clutch nut
Standard Honda ones, no idea what weight they are.
I'm past 50 and can assure you that you'll never have all the toys you need.
Re: Clutch nut
Forgot to mention I changed the airfilter as well.
Part of the service kit I got from ebay.
Re: Clutch nut
Have you tried a gatorgrip from yer local homebase?
Re: Clutch nut
Isn't that a fancy socket type thingumabob?
The problem isn't getting a hold of the nut, its holding the clutch bell in place.
Re: Clutch nut
gn2 wrote:Isn't that a fancy socket type thingumabob?
It's a grippy rubber belt in a plastic handle. Only has two parts. Thread the belt around the housing and pop it back in the handle
As the housing moves the whole thing tightens up.
trigg123
Re: Clutch nut
Post by trigg123 »
I us the same tool used for the variator,
never had a problem.....
Re: Clutch nut
What variator tool do you have?
The tool I have I made out of scrap plywood and bolts.
When used on the variator it catches on the stand which holds it in place while I give the nut some welly.
When it goes on the clutch there's nothing for it to catch on so I'm struggling to hold it in place while I work the ratchet.
Hmmm, just had an idea, maybe I'll try placing a brick or block of wood under it...
Re: Clutch nut
gn2 wrote:What variator tool do you have?
Class
Alibally
Clutch nut
Post by Alibally »
I made one of these. It works fine on the variator but haven't tried it on the clutch.
ImageUploadedByTapatalk HD1370983702.811338.jpg (69.8 KiB) Viewed 5042 times
Re: Clutch nut
That looks like it would be OK on the clutch.
One of the key differences between the clutch and the vario is that the clutch doesn't have the bolt holes for the holder.
Re: Clutch nut
you you wrote:It's a grippy rubber belt in a plastic handle. Only has two parts. Thread the belt around the housing and pop it back in the handle
This is what I bought this afternoon, worked an absolute treat.
The particular version I got was one of these.
First take the variator off.
Next fit the strap wrench round the clutch bell and pop the handle inside the casing to hold it in place.
This leaves both hands free to work on getting the nut undone.
Cheers you you, the winning suggestion!
Have a gold star.
Re: Clutch nut
That strapping tool is genius! Have used it on plumbing bits and you name it! Cheers youyou! And to me Mum for buying it when I didn't even know what the devil it was! See, youyou and gn2 Can Be Civil to one another :P We have witnessed ;)
It would be cool to see a pic of that strap wrapped and snugged up the way you mentioned gn2, (hands free)...by any chance you snap one? Just asking ;)
Re: Clutch nut
Sorry, didn't think to take pics.
The thing is all bolted back together now and I ain't taking it to bits again.
Re: Clutch nut
Alrighty then ;) (as I turn mumbling...Dang it! I shoulda asked sooner! I know, bad grammar :geek: )
