New LED Headlights
Brice
New LED Headlights
The old headlights lost their high beams. Time to replace. Any LEDs out there?... Amazon, no. Ebay, no,
Let's see what Ali Baba has...
https://www.aliexpress.com/item/1005002 ... 4c4dbX9Lkj
There have been a few discussions about the LED headlights. So for the sake of knowledge gathering, I bought them, installed them and have been using for about 200 miles this spring.
The main concern for me is that they last. I can't get my hands worked under and around and still have still have strength to remove the headlights. For me this is remove the panels job. bah.
The Order: They came within the schedule time. 2 weeks I think
The Fit: They fit as frustrating tight as the others.
The Illumination:
Daytime: Bright. I think brighter than the originals. When I checked them out, I feel that my visibility is better than before.
Nighttime: I have only driven at night a few times with the old ones. The old didn't impress me. I have yet to give these a road test, but in my driveway these didn't impress me either, they may be even a little worse than the old ones. I do know I'll need to keep the lows on when passing traffic. There are bright in the daytime. They could be blinding at night.
Verdict: Time will tell. If I get 2 years (10k miles) out of them, I'll proclaim them a good deal.
Note: I am fortunate that while I replacing the headlights, my body screws screwed like rabbits. I had a couple screws in the screw pan! Lucky me! They must have made babies. Either that or I didn't replace get them all back in the panels. I'm going with the reproduction theory. Its much easier on the ego.
The Illumination:
mymitzi
Re: New LED Headlights
Thanks for sharing. Were you able to project the new lights on a wall, to see/compare the pattern?
Hope they get the job done for you. Sure seems reasonable. Have had screw proliferation too. : )
- pcx888
- Color: pearl white
Check out my link I have info for complete led setup.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
mymitzi
Thanks pcx888
Thanks! I have now ordered some! I have been waiting for them to start selling the led bulbs in lots of less than 100, since they seem to be the only ones left who sell them. Even though I know that I will have to sell my bike soon enough, I still want led headlights. (I already have led aux lights that I turn on every time I ride, but more is better.)
Brice
Mel,
When you do yours, can you do a before and after comparison like mymitzi suggested? I wish I thought of using a wall.
The price is definitely reasonable. There are few different vendors, not that I can tell one from another about quality.
I actually luck with another Ali Baba vendor. I got a refund on a product that went bad! So I if this LED goes bad within a year, I'll ask for refund and hope for the best.
Good luck with yours
I would not recommend those style LED headlight bulbs.. If you are going to to go LED go with something like this. Cluster LED bulbs like the ones you bought are much more likely to short out quicker.
Either way I would highly recommend HID over LED for longevity. Ive experimented a LOT with HID vs LED and LED never lasts as long. Not bc the LED is bad, but typically these cheap china made LEDs have much more opportunities to fail. HID is just 1 bulb.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
I agree with Conlite in that LED lights don't seem to last as long as the manufacturer installed ones, but the trade off is much much brighter lights. I have aux LED lights installed on my bike with a separate switch on the handlebar so that I won't be left in the dark if the bulbs burn out while riding at night. I may by a backup pair of bulbs later on, after I test the pair I just ordered. No one else seems to have HS5 LED bulbs.
I have installed LED bulbs in my older car and they usually burn out after 5 or 6 months. As expensive as it gets to replace those bulbs, the tradeoff is like night vs day. I solved that burn out problem by adding a DRL strip to my car and not turning the headlights on until dusk. By the way Conlite, the last led bulbs you showed a picture of as preferred, well those are what I have in my car. Even they burn out.
On the bike, well, I will just have to see. I have taken my bike apart quite a few times, so no fear there, but I am go ing to experiment with installation and removal of the bulbs to see if there is an easier way to do it.
Hopefully I can find a spare wall to use to check the lineup of the beams.
ha ha ha. Same. I switched from HID to LED's on my Element. They were great for maaaaybe a year then it started to dim. Didn't think much of it but just kept getting work. This is what was left. one unit had only 1 LED on, the second one both LED's actually de-soldered themselves off the housing. Back to HID's I went.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
affeno
- Color: red
Hello I have tried a lot of diffrent led lights on my pcx 2013 and find out that philips -hl-M5 is very good very bright and good picture
- RIMG1064.JPG (203.79 KiB) Viewed 9558 times
affeno
- Color: red
I live in Thailand and this socket are on all small motorbikes like pcx
comecamino
small motorbikes like the old Honda cg125, forget about installing those in a pcx, the connector doesnt even match! wtf
Honestly guys the best you can do is buy the proper halogen bulb, because the led simple does not offer the same light amount/quality/distribution (or whatever you wanna call it) to be reflected in the back of the headlamp in order to direct the beam correctly..... at the end at night either you will have to adjust the height upwards thus blinding other people with the light turning you into the most despicable human being on your area or, you wont see a thing because the beam points too low.
Sincerely I have a *really* small hope that some manufacturer would make a proper (homologated) HS5 retrofit because this precisely bulb as far as I know is not that common and we all know how capitalism works
