What should I do about this rust?
Carzah
Post by Carzah »
I thought I would give the bike a quick wash and noticed this rust. It's the first time I've looked under here since I got the bike last year. It's a 2019 PCX 125 with about 5,000 miles.
It's the only rust I can see other than a tiny bit on the exhaust. I'm pretty new to vehicle maintenance so I'm not sure how bad this is or how to treat it.
Any help/suggestions would be appreciated.
Year: 26 adv 160
Re: What should I do about this rust?
wire brush it and paint on some rustoleum rust arrestor from home depot.
Conelite
Color: Blue
Post by Conelite »
What Jge64 said. Nothing a little wire brush and rust prevention spray paint. Rust-Oleum Rust Reformer Aerosol Spray. Then paint it black.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Old Scoot
Post by Old Scoot »
I would go back to the place you bought your scooer
You've found one of the few areas of the PCX which demands constant maintenance.
The black yoke and chrome stanchions need to be rubbed over with ACF50 at least once a week, daily in winter, to stop this corrosion forming.
If the stanchions corrode in the working area it can cause oil leaks through damage to the seals and bushes.
Carzah
Post by Carzah »
Thanks for the suggestions guys.
I just got done using a wire brush and some sandpaper, then applied a coat of this stuff.
https://www.hammerite.co.uk/product/dir ... th-finish/
I have also ordered some acf-50 to cover the while bike in. Hopefully this will keep it at bay.
Thanks again. :)
springer1
Year: 2018
Post by springer1 »
gn2 wrote: Sun Feb 28, 2021 6:03 am You've found one of the few areas of the PCX which demands constant maintenance.
Thanks for that tip, I've not heard of this ...... sounds like it's a WD-40 on steroids and it's also a lubricant where WD-40 is not.
Thanks
