I thought I would give the bike a quick wash and noticed this rust. It's the first time I've looked under here since I got the bike last year. It's a 2019 PCX 125 with about 5,000 miles.
It's the only rust I can see other than a tiny bit on the exhaust. I'm pretty new to vehicle maintenance so I'm not sure how bad this is or how to treat it.
You've found one of the few areas of the PCX which demands constant maintenance.
The black yoke and chrome stanchions need to be rubbed over with ACF50 at least once a week, daily in winter, to stop this corrosion forming.
If the stanchions corrode in the working area it can cause oil leaks through damage to the seals and bushes.
gn2 wrote: ↑Sun Feb 28, 2021 6:03 am
Thanks for that tip, I've not heard of this ...... sounds like it's a WD-40 on steroids and it's also a lubricant where WD-40 is not.
