OBD2 on Honda PCX that works!
Rineymotorsports
Re: OBD2 on Honda PCX that works!
Post by Rineymotorsports »
MadSteamer wrote:Hi there,
I thought that I share my latest discovery on connecting cheap Bluetooth OBD2 reader to the PCX. All you need is:
-cable from here
https://www.lonelec.co.uk/Honda-4pin-OBD2-Adaptor
-Generic Bluetooth OBD2 transmiter/reader
-Torque app
You plug the cable to PCX red service port next to the battery and that's it.
You can read all the data available without expensive gauges.
Thx!
What year PCX do you have I have a 2013 but I'm swapping the drivetrain on to a Ruckus I ordered one of those plugs a week or two ago and haven't seen it
Conelite
Color: Blue
Post by Conelite »
Doesn't work on 2017.
I bought the Kitaco Adapter and the ELM BT scanner. No data is transferred thru the Kitaco. my ELM scanner works flawlessly on my car.
I also tried another plug and play aRacer Display but no data. Waiting to hear back from aRacer for a firmware update to get it to work.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
pcx888
Color: pearl white
Post by pcx888 »
Conelite wrote:Doesn't work on 2017.
Any Luck
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
There is a wire difference from info found searching google - or at least one pin one end does not mate the same way all the time to the other connection - not sure what is correct in any circumstance. Be good if people get it working for a certain year range of PCX to show all the parts and links that are known to work.
This topic comes up every now and it seems all (most?) people other than the original poster do not get it working.
Aldi (UK) have their XS branded OBDII on sale again 31st Dec - some have luck using it on cars, many don't. No idea if it will work with the PCX - probably not as success rate seems to be very low no matter what adapter and reader.
Rineymotorsports
I couldn't get it to work on my 2013 PCX It actually locked up my daughter's computer and I had to take the computer Apart and unplug the battery for it to come back on Didn't try it again
wrighty
Color: White fastest!
Post by wrighty »
Hi,
What works on a pcx 125 2016?
I've got an engine light on and speedo isnt working!
amin12345
Post by amin12345 »
If anyone finds a working device to scan the PCX pls post it here.
For all the posts on a working OBD solution for the PCX, and there has been about three over the past few years, most except the starter of a thread seem to have no luck at all - even accounting for the differences in wiring of general OBD devices and the PCX (the data line is often on another pin, images and comparisons have been posted but alas it seems to make no difference).
Strange, as some should have got it working but none but the originators of these threads seem to have any luck on PCX's.
Conelite
Color: Blue
Post by Conelite »
pcx888 wrote: Sun Dec 27, 2020 5:30 pm
Any Luck
No luck at all. I gave up on getting an OBDII reader to work on my PCX.
2017 PCX 150
Wirus Win Exhaust
Z-Bars
NCY Variator
Off a link from the webpage shown in the 1st post, at the bottom of a software sales page it states:
1 Only reading of Keihin based ECUs is supported at this time.
2 Most (if not all) R8C based ECUs with a memory offset of 0x8000 can not be read via K-line.
3 Only works official HRC ECUs.
No idea what this means esp. with regard the PCX and orginal ECU, but googling off this snippet I found:
https://www.alientech-news.com/en/k-suite-4-13/ which lists the PCX 150 and off that:
https://www.alientech-shop.com/product/144300k270/
Gave up at this point as waiting for guinea pig to risk it - ha!
pcx888
Color: pearl white
Post by pcx888 »
Still can't find anything that works. It sucks.
2011 White PCX
bogas
Color: Grey
Post by bogas »
pcx888 wrote: Mon Aug 02, 2021 12:39 am Still can't find anything that works. It sucks.
Hello. In my pcx works ELM327 1.5 version. 2.1 will not works.
Like this:
https://a.aliexpress.com/_mOOZTL4
pcx888
Color: pearl white
Post by pcx888 »
I have that version that still doesn't work.
2011 White PCX
