I put all leds. no flickering on my end.Gil wrote:Halogen light bulbs for the headlights, the rest are still LED.
Retrofitting to European Lighting
- pcx888
- Color: pearl white
Re: Retrofitting to European Lighting
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
- Gil
I think it was the LED headlight bulbs that I added that caused it, they had eight LEDs per bulb. Which ones did you use?pcx888 wrote:I put all leds. no flickering on my end.Gil wrote:Halogen light bulbs for the headlights, the rest are still LED.
Also, good to hear that it was only on my end.
Gil
pcx888,
What was the bulb type you used for your main beams? The standard for 2011 - 2013 is HS5, which no longer comes in LED form. I would love to change mine to LED but I would have to change the base, plus find bulbs that fit in the wattage recommended (35/30).
- pcx888
Mel the headlamp assemble is now 119.00 on ebay with all cutout on the assembly. and uses 9003 bulb assembly.Mel46 wrote:pcx888,
Ebay item number is 303733963884.
2011 White PCX
