Ankle Biter
Conelite
Color: Blue
Ankle Biter
Post by Conelite »
So I have always been a fan of Custom CVT covers and/or Ankle Biters. I think it gives Scooters such a custom frankenstein look to them. Even uncovered CVT's look crazy and rugged. So I found a guy Harvey that has been cutting and selling PCX Ankle Biters and instantly bought it. It came rough from the raw Aluminum so I wanted to do some step sanding and polish it.
Took about 8 hours of step sanding and hand polishing but It was well worth it. Painted the Bell to give a nice contrast. Enjoy.
So this is how the cover comes. Raw Material + Hardware.
This is after 350/400/600/1000 wet sanding then first pass with Mothers.
Tried a buffing pad but due to it being so thin, I just ended up finishing it by hand.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Year: 26 adv 160
Re: Ankle Biter
Very nice!
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Re: Ankle Biter
Post by alx123 »
So your'e gonna run the scoot with that part right there open?
Coasting
Re: Ankle Biter
Post by Coasting »
Personally, I'd be concerned about running the clutch assy without the left hand end of the shaft being supported (The original CVT cover has a bearing that the shaft is supported by).
Re: Ankle Biter
Coasting wrote:Personally, I'd be concerned about running the clutch assy without the left hand end of the shaft being supported (The original CVT cover has a bearing that the shaft is supported by).
+1
Yep, bearing is out there for a reason.
Old Scoot
Re: Ankle Biter
Post by Old Scoot »
o_O I just don't understand how people can come up with such [stupid] idea's, the complete CVT is covered for a reason by the manufacturer.
Sure it looks nice but spend a little more money and buy / make a transparent cover to protect the CVT and yourself if you want to show the CVT assembly ;)
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
ha ha ha ha. I love the hatred for anything Original in this group. Im a form over function kinda guy (with a very well tuned bike). :D
I'm not one bit worried about anything going into the CVT or clutch, nor worried about any extra bearing wear due to removing the clutch shaft bearing. Ive run with no CVT or open cover on multiple bikes with no issues. Its not a GY6 so Im not worried about Swingarm cracking plus this bracket is just as sturdy as stock.
This is not my primary transport so if something fails, I'm not walking. The sound and look of this thing is well worth the risk (which is very minimal).
2017 PCX 150
Z-Bars
NCY Variator
Re: Ankle Biter
Looks good tbh.
What about removing the redundant mounting brackets?
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
you you wrote:Looks good tbh.
Thanks, I know its not for everyone. I also know that the majority of people on this forum care about longevity and MPG. 2 things I dont really care. Im of the mindset that if it breaks, build it bigger and better. ha ha ha.
Im assuming you are talking about the outer bracket? If so, the point of that is so its mess likely for you to hurt yourself if you brush up against the CVT while you get off or on.
Plus it looks really weird without it and the Clutch bell sticking out.
2017 PCX 150
Z-Bars
NCY Variator
alx123
Bangkok Rider
Bangkok Rider
Color: Fast White
Re: Ankle Biter
Post by alx123 »
Seriously, I will remove the bracket too.
then Paint multiple attractive colors on the clutch bell so that it looks much nicer when it turns, like a color wheel.
Also, if it's possible to make the belt more visible.
Watching that will be the same as staring at those beautiful skeleton mechanical watches, they never fail to astound me.
Coasting
Re: Ankle Biter
Post by Coasting »
Conelite wrote:I love the hatred for anything Original in this group.
I don't "hate" it; By your own declaration you're a "form over function kinda guy" and in contrast, I'm a "don't fix it if it ain't broke" kinda guy.
Many here have replaced many parts (windscreen, variator, shocks, seats are some that come to mind) whereas I'm 100% satisfied with the OEM versions of all those types of parts.
Horses for courses and all that.
Year: 26 adv 160
Re: Ankle Biter
I like it. I understand why you did it, and obviously you’ve got some acumen about this because you own Flex Rotary… Don’t know too many people that have that. I do worry a bit about the rear bearing not being supported, but only if I was going to keep something for tens of thousands of miles, and ride it into the ground. I don’t keep my bikes more than three years, I like new stuff. So it wouldn’t bother me. I actually may do this modification.
Ps With that rotary you could probably get it to be a mirror finish using a true polish set, like Meguires 105 and then 205.
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
Jge64 wrote:I like it. I understand why you did it, and obviously you’ve got some acumen about this because you own Flex Rotary… Don’t know too many people that have that. I do worry a bit about the rear bearing not being supported, but only if I was going to keep something for tens of thousands of miles, and ride it into the ground. I don’t keep my bikes more than three years, I like new stuff. So it wouldn’t bother me. I actually may do this modification.
I didnt use the hand buffer/Flex Rotary too much. It was a little too hard to hold the part and polish it at the same time. It was mostly done by hand so not the best finish. Im hoping next time it needs a good polishing I can get my hands on one of these. Then for sure it would be a mirror finish. ha ha ha ha
Screen Shot 2020-10-21 at 8.10.33 AM.png (99.51 KiB) Viewed 9328 times
2017 PCX 150
Z-Bars
NCY Variator
Re: Ankle Biter
No I meant the redundant brackets on the crankcase for a cleaner look.
Or maybe pop some bolts in to cover the exposed thread
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
Working on a Radiator cover now with my Buddy HE Fab Works..
2017 PCX 150
Z-Bars
NCY Variator
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
Finally finished my radiator cover. Didn't polish it like I did the Ankle biter but I'm happy with it. If and when i stretch it, should look real nice.
2017 PCX 150
Z-Bars
NCY Variator
Re: Ankle Biter
Looks great.
What is the weight compared to the parts removed?
Conelite
Color: Blue
Re: Ankle Biter
Post by Conelite »
you you wrote:Looks great.
The CVT cover for sure weighs less. lol The Rad Cover probably weighs more. ha ha ha
2017 PCX 150
Z-Bars
NCY Variator
